Windows 10 warning
Old Aug 4, 2015 | 02:10 PM
MIKES 68 F100's Avatar
MIKES 68 F100
Exclamation Windows 10 warning
I know this is the wrong area for this but wanted to share .
If you have the Windows 10 upgrade Icon (bottom right corner 4 pane white window )
With this update you are letting Microsoft use your Bandwidth to help others upgrade to windows 10 . I got hit hard by this at work having about 100 pc over 3 locations . slowed my work environment to a crawl .
you can stop this
just go to add remove programs >view installed updates > in top right corner "search box " type KB3035583 high light it and uninstall . you will need to reboot your PC .
final step is go into windows update and uncheck the same KB3035583 hit ok . this keeps windows from shoving it back on to your pc the next time you boot .
Old Aug 4, 2015 | 02:33 PM
JEFFFAFA's Avatar
JEFFFAFA
you can stop this
I personally am glad you did Mike. I copied and pasted this on an email and sent it back out to all my friends and customers. Right On Mike.
Old Aug 4, 2015 | 02:34 PM
Gembone's Avatar
Gembone
How to Disable Windows Update Delivery Optimization (WUDO)?
You can disable the feature, but the option is buried deep in the Settings menu for Windows Update.
To turn this feature OFF, follow these given steps:
  • Go to Settings in the Start menu
  • Search for Update & Security
  • Under Windows Update, open Advanced Options
  • Under Choose How Updates are Installed, select Choose how updates are delivered
  • Disable the toggle under Updated from More than One Place
Old Aug 4, 2015 | 02:37 PM
JEFFFAFA's Avatar
JEFFFAFA
Well, Danke Schoen to you also Greg.
Old Aug 4, 2015 | 02:53 PM
MIKES 68 F100
Glad to help out Fellow FTE members
Thanks Greg .
I guess nothing is for free on the internet .LOL
timmyboy76
Mar 27, 2019 10:39 AM
truckfella
Oct 31, 2013 12:32 AM
xc4jokestomper
15
Aug 1, 2011 10:28 PM
mizzitch
May 10, 2007 04:17 PM
