Intermittent power loss
Whats became of this
suppose it could take a pcm out
were any fuse blown ?
Vref still at 5 volts?
I haven't done an end-to-end continuity test or an isolation test on the harness, just visually inspected. This is my next move, to disconnect both the PCM and EGR valve and measure continuity and perform isolation testing between conductors. I have a high pot tester to measure insulation resistance to detect potential rub throughs between conductor-conductor and conductor to chassis. I did measure vref with the DVOM and it was 4.98V.
It’s important that you must meet the operating conditions at top left of this spec sheet when you take sensor values
check values when it’s running rough maybe something will stand out post values for low idle and high idle2500 rpm
Exhaust Gas Recirculation Monitor:
EGR System and Comprehensive Component Monitors:
The Delta Pressure Exhaust Gas Recirculation (EGR) System is a closed loop EGR Valve Position control system.
It utilizes an exhaust manifold pressure sensor, an intake manifold pressure sensor and a speed density estimate of total mass flow and derives a desired EGR Valve position based on a desired EGR flow percentage.
The EGR Monitor is a series of electrical tests and functional tests that monitor various aspects of EGR system operation.
When normal EGR rates are being commanded and when the engine enters into either one of two specified operating ranges, a flow check is performed. The operating ranges are defined to insure an adequate amount of EGR is being requested to allow for an accurate estimate of the EGR flow percentage. At this point EGR flow is estimated based on the difference between the Mass Air Flow (MAF) sensor reading and the total mass flow calculated by the speed density calculation. The estimated EGR flow is then compared to the expected EGR flow to determine if there is insufficient or excessive flow.
Exhaust Gas Recirculation Position Sensor (EGRP):
DTCs:
P0406 – Exhaust Gas Recirculation Sensor A Circuit High
Monitor Sequence: None
Sensors OK: Not Applicable
Typical Monitoring Duration Less than 1 second
Typical Exhaust Gas Recirculation Position Sensor Entry Conditions:
No entry conditions.
Typical Exhaust Gas Recirculation Position Sensor Check Malfunction Thresholds:
Voltage less than 0.30 volts for P0405 and voltage greater than 4.90 volts for P0406
Exhaust Gas Recirculation Valve Actuator (EGRAM) Monitor Operation:
DTCs
Monitoring Duration: Less than 1 second
Typical Exhaust Gas Recirculation Valve Actuator Monitor Entry Conditions:
No Entry Conditions
Typical Exhaust Gas Recirculation Valve Actuator Monitor Malfunction Thresholds:
Actuator driver status indicates open/short
Exhaust Gas Recirculation (EGR) Valve:
DTCs:
Sensors OK: Exhaust Gas Recirculation Position (EGRP)
Typical Monitoring Duration: Greater than 10 seconds.
Typical Exhaust Gas Recirculation (EGR) Valve Entry Conditions:
Engine Running: (mode = 2)
Typical Exhaust Gas Recirculation (EGR) Valve Thresholds:
+/- 0.10, out of a total working range from 0 to 1, error from the commanded position to the actual position.
Exhaust Gas Recirculation (EGR) Monitor Operation:
DTCs
P0402 – Exhaust Gas Recirculation Flow Excessive Detected
Sensors OK:
Mass Air Flow Sensor (MAF)
Barometric Pressure Sensor (BARO)
Intake Air Temperature Sensor (IAT)
Engine Oil Temperature Sensor (EOT)
Manifold Air Pressure Sensor (MAP)
Exhaust Pressure Sensor (EP)
Exhaust Gas Recirculation Valve Actuator Monitor (EGRAM)
Electronic Variable Response Turbocharger Actuator (EVRT)
Typical Exhaust Gas Recirculation (EGR) Monitor Entry Conditions:
Exhaust Gas Recirculation is commanded greater than 10% open and one of the following conditions exist.
Condition 1: Engine speed (N) 1000-1800 RPM and fueling desired (MFDES) 10-16 mg/stroke.
Condition 2: Engine speed (N) 1800-2500 RPM and fueling desired (MFDES) 12-29 mg/stroke.
Typical EGR Monitor Malfunction Thresholds:
Limits based on engine speed and load.
