2004 ford exped. code 1290 i believe. cylinder head temp sensor.removed intake.located sensor area,NO SENSOR.WTF? dunno if this is normal..put one in..problem is no wire harness to plug into sensor
That is the location for the 2-valve engines. I've attached the procedure from the FSM for the 4V engine.
Should be there in the cylinder head, front driver's side, under the intake manifold. But you wouldn't need to remove the intake to swap it out. Just remove the alternator and you have access to it. It's a dry sensor, no coolant touches it. Does your temp gauge work in the instrument cluster ?
Should be there in the cylinder head, front driver's side, under the intake manifold. But you wouldn't need to remove the intake to swap it out. Just remove the alternator and you have access to it. It's a dry sensor, no coolant touches it. Does your temp gauge work in the instrument cluster?
Are you sure? I ask because for 4V engines the FSM instructions say, "5. NOTE: The CHT sensor is located at the back of the right side cylinder head."
