throttle body
Old Jan 23, 2025 | 01:54 AM
hemp's Avatar
hemp
4th Gear
throttle body
ok guys..i feel as this is new jack ****..i being that new jack...first time ive ever done this removing of top end **** to get to that cylinder sensor..so put it all back and it started..that was a semi proud moment..so now it seems as if the slight touch of the throttle butterfly threw my throttle off..got a position sensor code..neighbor said i would have to go put it on a dyno to have them recal the throttle i guess..dunno if theres a way to reset throttle or willl i have to go put on a dyno? reaching out to yall for help..im most def a novice so any help would be a blessing..thanx guys
Old Jan 23, 2025 | 06:04 AM
broncoholic's Avatar
broncoholic
I question if you did the reassembly correctly. Did you get all the vacuum lines and electronic plugs reconnected, specifically the throttle position sensor? When I replaced my intake, I gave the throttle body a good cleaning including rotating the throttle. I reassembled everything correctly and had no issues.
I've also never heard of recalibrating the throttle on these either.
Old Jan 23, 2025 | 06:54 AM
alloro's Avatar
alloro
Ditto on double-checking the assembly. If you're getting a throttle position sensor code, then it's likely that didn't get plugged back in.
Do you have a scan tool to read the trouble codes? If so, post the code numbers here which will help us, help you.
Old Jan 23, 2025 | 11:06 PM
hemp's Avatar
hemp
4th Gear
CODES
SO GUYS..PULLED 6 CODES TODAY..FUNNY CUZ MY REASON INITIALLY WAS THAT CODE FOR THE CYLINDER SENSOR...SO I SEE THAT THE CODES ARE MOST LIKELY DUE TO ME AND MY RE INSTALL OF,OR SHODDY RE INSTALL BUT I DUNNO..ANY TIPS ..OPINIONS OR SCOLDING IM ALL EARS
CODES
P 0171...0155..0135..0403...0443...0446
Old Jan 24, 2025 | 07:23 AM
alloro's Avatar
alloro
Seems like a few things didn't get reconnected.
P0171 - Vacuum leak
P0135 - O2 heater circuit
P0155 - Driver's side pre-cat O2 sensor
P0403 - EGR circuit
P0443 - EVAP purge solenoid
P0446 - EVAP vent valve
Susyqt45
Apr 6, 2023 05:56 PM
ncguy23
22
Jul 25, 2007 10:20 PM
JakeTheSnake
Jul 18, 2006 03:57 AM
Firewiz
2004 - 2008 F150
Jun 14, 2004 04:57 PM
Mzche
Jul 23, 2001 01:26 AM
