help
Old Jan 16, 2025 | 01:15 PM
hemp's Avatar
hemp
4th Gear
help
2004 ford exped. code 1290 i believe. cylinder head temp sensor.removed intake.located sensor area,NO SENSOR.WTF? dunno if this is normal..put one in..problem is no wire harness to plug into sensor
Old Jan 17, 2025 | 07:31 AM
alloro's Avatar
alloro
That is the location for the 2-valve engines. I've attached the procedure from the FSM for the 4V engine.
File Type: pdf
Old Jan 17, 2025 | 09:38 AM
Hamfisted's Avatar
Hamfisted
Should be there in the cylinder head, front driver's side, under the intake manifold. But you wouldn't need to remove the intake to swap it out. Just remove the alternator and you have access to it. It's a dry sensor, no coolant touches it. Does your temp gauge work in the instrument cluster ?
Old Jan 17, 2025 | 12:15 PM
alloro's Avatar
alloro
Originally Posted by Hamfisted
Should be there in the cylinder head, front driver's side, under the intake manifold. But you wouldn't need to remove the intake to swap it out. Just remove the alternator and you have access to it. It's a dry sensor, no coolant touches it. Does your temp gauge work in the instrument cluster?
Are you sure? I ask because for 4V engines the FSM instructions say, "5. NOTE: The CHT sensor is located at the back of the right side cylinder head."
Old Jan 17, 2025 | 02:48 PM
Hamfisted's Avatar
Hamfisted
The '04 Expy still has the 2V motor.
Old Jan 18, 2025 | 11:26 AM
alloro's Avatar
alloro
Here is the 2V procedure.
File Type: pdf
Old Jan 21, 2025 | 02:50 PM
hemp's Avatar
hemp
4th Gear
thank u
Sigma01
2010 - 2014 Ford SVT F150 Raptor
May 22, 2022 08:53 AM
Rob Thomas
Modular V8 (4.6L, 5.4L)
Jun 17, 2017 09:42 AM
darknight
Apr 4, 2015 07:05 PM
rn360908
Aug 8, 2011 07:14 PM
