Odd trans issue e4OD
Old Jan 15, 2025 | 11:16 AM
OxBow0's Avatar
OxBow0
Hey all, I ran into an odd issue I would love some input on:
1993 F250 E4OD RWD extended cab 7.3L IDI about 195k miles.
recent complete fuel system overhaul, new IP, new TPS, new lines, new fuses, etc.
TPS set at 1.21 idle @600rpm, WOT is 4.34
timing at 10*
runs great but…. A maxi fuse popped (my fault) and so I grabbed the third one down on the left side engine bay to replace to get to the store.
whn driving this way, starting from a stop was like a massive load on the truck, but after that it ran better and smoother then ever before, but no OD.
with new fuse installed it was back to normal, which means good, but irritating shift points for my smooth drive style. Shifting is now @ about 1800-2200 rpm, and next gear starts at about 800 rpm. That stinks to me.
Ideas?
addition: I am suspicious of the solenoid pack, given then up shift to 3rd from 2nd without delay. If that’s the case, a pack replacement may be needed. If that’s the case, suggestions on the best aftermarket or stock setup?
Old Jan 15, 2025 | 06:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are two ways to fix this. One, just buy parts and swap them until you get lucky or run out of money. Second, read the codes and KNOW what's wrong and needs to be fixed or replaced.
Here's how to read the codes: www.troublecodes.net/ford
Old Jan 15, 2025 | 06:43 PM
OxBow0's Avatar
OxBow0
Thanks, I checked and other then when fuse was out, no other codes popped up. That was the first place I went. Purhaps a 10 mile drive to see if anything triggers?
Old Jan 15, 2025 | 07:00 PM
Mark Kovalsky
Yes.
Old Jan 15, 2025 | 11:45 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
You don't like it shifting so late, with higher rpms? Try adjusting the TPS down to about 1.19 or 1.18. The next "shift" at just a few more rpms, is probably the converter locking. Tweak your timing back down around 7 or 8 BTDC and see if it feels better when the converter locks.
Old Jan 17, 2025 | 08:19 AM
OxBow0's Avatar
OxBow0
Ok, only code is 26 (MAF), which is odd. My issue is that it seems to shift too early, and then seems to lug (like 800 rpm). I’d like it to shift over 2k, but it shifts at about 1600.
Old Jan 17, 2025 | 08:47 AM
WCMtn1990's Avatar
WCMtn1990
Are there any dead spots in the voltage sweep on the new TPS? Proper 5v reference input? Also, isn't idle of 600rpm below spec? I thought idle was supposed to be 650-700rpm while in Drive.
Old Jan 17, 2025 | 09:25 AM
OxBow0's Avatar
OxBow0
Ooo
References 5.0 VDC, otoscope check of the TPS sensor shows no dead spots, I always check even new ones.
when I set the idle at 650rpm with my foot on the brakes in drive, the truck would pop a code 23, which, according to my chart, means idle too high.
I might retard the timing in a couple of days when it’s not an ice storm and see if that helps
Old Jan 17, 2025 | 10:36 AM
FORDF250HDXLT
Code 62 on our trucks is the converter not locking when it should be locked. 23 is TPS code. If you don't hold the fuel pedal to the floor during the scan, it will always set code 23 and you won't know if it's a real code or not. Be sure to do the scan while holding the IP lever wide open. A true 23 code can cause the 62 code. You may have a bad TPS even if it's new. I've gotten one bad out of box before.
https://www.therangerstation.com/tec...des/#gsc.tab=0
Edit; oh my bad. I'm so used to seeing code 62 haha you said 26. That's a bad TOT sensor code. hmmmm. Start here:
E40D: The Importance Of A Clean Trans Harness
Disregard engine timing (though I prefer 7 BTDC, you should experiment) it's unrelated to your current issue, in light of codes.
Old Jan 17, 2025 | 01:48 PM
OxBow0's Avatar
OxBow0
Thanks for that, my manual doesn’t mention WOT during codes.
update though: I reduced timing to 5* advanced, no change, so set it back to 8*
with AND w/0 overdrive I seem to be missing 3rd going up, thus the drop to 800rpm.
i CAN WOT when ******* in 4th and it will drop into 3rd that way, then shift asap to 4th.
drove 48 miles
im thinking solenoids, but could it be the controller?
Old Jan 17, 2025 | 06:55 PM
FORDF250HDXLT
If the connector is clean, you can test the pack.
Originally Posted by FORDF250HDXLT
Testing it is actually VERY easy, You'll be messy, but drop the pan, pull the filter, unbolt it, unhook the wire, pop it down out of there (you don't have a repair plug ou can just plug into it) and put on a clean surface.
Get out your multi meter and follow the instruction is the prior photo of what it should read for resistance. If it's not within specs, which it's probably not, since you already tested the line from TECA to the solenoid pack plug, right? I think you claimed you did that already. Do it again anyway, making sure all wires reads 0 ohms and if the solenoid isn't within like, what was it? 5 ohms or so, right?
Also note this: Apply 12v power to the + pin of the EPC and ground the - pin. When you ground the - pin with power supplied to the +, you should hear it click on/of as you connect ground and remove it........No click......bad solenoid. Replace the pack. Same if it doesn't read within spec of resistance.
If it's within spec, and all your wires have 0 resistance from TECA to Solenoid pack plug, then and only then, would I blame the TECA and replace it (with a '94 TECA).
Just keep this in mind:
The odds of a poor connection (corroded wire/bad wire, poor pin connection) causing code 99 = 95%
The odds of a failed solenoid pack 4%
The odds of a failed TECA 1%
That's not exact of course, that's my best guess, but I bet it's VERY close! Maybe I should have left a % for something else, but I don't know what else could fail to set this code......I'm pretty sure this is it.
Oh. Almost forgot, but note solenoid packs are year specific. If you need to replace it; be sure to use the PRE 1995 pack. That's the '89-94 pack for IDI trucks with the E4OD. They take "good" effort to pop in and out......Don't be afraid of it.
Any good reman or used according to budget is good. They rarely fail. I would trust a tested used one in my work trucks that I count on to make money, so. If you can afford a reman pack just the same.....go with that. You'll get a brand new, clean electrical connector installed in it. Never mind the nice new solenoids haha this is more important. (joke placing emphases on how vital clean connectors are so important.)
Old Jan 17, 2025 | 11:38 PM
WCMtn1990's Avatar
WCMtn1990
The idle might not be a factor but mine is abut 675rpm and I have run the Innova ODB1 scanner several times KOEO test while holding throttle at WOT and never got a code regarding idle. I got the barometric sensor code but I unplugged the connector and blew some dust out and then ran the test again and code went away. I also think if you run the KOEO test without holding WOT you will get a barometric sensor code.
Old Jan 18, 2025 | 10:45 AM
OxBow0's Avatar
OxBow0
Being a diesel, it’s oily on the trans area. I’ll start with a thorough cleaning, and elec check and go from there. Thanks very much, I’ll post an update when I get a chance later this week.
ice and snow two days, no covered shop yat
Old Jan 21, 2025 | 10:09 PM
OxBow0's Avatar
OxBow0
Ok, update!:
harness looks good, cleaned both sides thoroughly, di-greased, and did a 40 mile test drive. 2-3-4 all great! Shift points perfect. However… only get 1st gear when direct shifting into it, not in 2 or drive/od. Otherwise power, economy, and engine rpms are now ideal. I ohm’d it out and all looks ok. No more codes. Other odd thing now is that towhaul on (OD off) no longer gives downhill compression, it just coasts like OD on.
Old Jan 22, 2025 | 11:19 AM
Mark Kovalsky
The first year that any Ford had tow/haul was 2003. How did you get it installed in your 1993? That must have been very difficult.
Does it have engine braking in manual 2?
What codes are stored in the PCM now? Here's how to read them on a 1993: www.troublcodes.net/ford
