Truck will not start - PLEASE HELP!
Old Jan 10, 2025 | 06:51 PM
STX Screamer's Avatar
STX Screamer
My 2018 F150 2.7 will not start. It sounds like it's struggling to turn over and just doesn't get there. Here is a video. We have tried testing the battery at Autozone and replaced the starter (had Autozone test the new one just to confirm it worked). Any advice would be great!!!
File Type: mp4
Old Jan 11, 2025 | 07:37 AM
SpencerPJ's Avatar
SpencerPJ
That does not seem to be a battery or starter issue, it's turning over fine. Maybe check fuel pump fuse? I'm guessing no check engine light?
Old Jan 11, 2025 | 10:12 AM
danman979's Avatar
danman979
look in your owners manual for the location of the impact sensor on your truck. that sensor is suposed to turn off your fuel pump in the event of an accident. some times it will trip if you slam your door too hard or you bump into the truck with some thing.
Old Jan 11, 2025 | 10:24 AM
GlueGuy's Avatar
GlueGuy
+1
That is not starter or battery. It's turning over just fine. It also sounds like there's spark, so I would go with the fuel/air.
Old Jan 11, 2025 | 06:14 PM
STX Screamer
Update, still down
Update, still down. I appreciate the input from everyone.
Checked the fuses, all are okay.
Replaced the fuel relay.
No check engine light or error codes are showing.
Next, I'll replace the fuel pump, I guess. Heading to Autozone. 😞😓😩
Old Jan 12, 2025 | 07:30 AM
SpencerPJ's Avatar
SpencerPJ
I am no mechanic, but certainly there are better ways to check fuel pump, that doesn't require dropping the tank, maybe disconnect under the hood and see if it pumps? My thoughts, I would quickly learn Forscan, and buy the dongle to connect laptop to obdii port. No start, it will have a code stored (and not part of the check engine light emission system) Good Luck.
Old Jan 12, 2025 | 09:12 AM
STX Screamer
It's so strange, even checking for codes with Forscan, none show up. I'll replace the fuel pump Monday morning.
Old Jan 12, 2025 | 11:55 AM
Picky1962's Avatar
Picky1962
I would check that there is fuel reaching the engine before just replacing the fuel pump. Then work backwards towards the fuel pump checking the fuel filter and fuel lines for physical damage. If you got fuel at engine then it's most likely a spark issue.
Old Jan 12, 2025 | 12:25 PM
GlueGuy's Avatar
GlueGuy
+1
If you disconnect the fuel line at the manifold, just turning on the ignition should spray fuel like crazy. It's very high pressure, so two people would be mandatory.
Old Jan 15, 2025 | 08:50 PM
blackestate's Avatar
blackestate
Can you rent a fuel pressure gauge from AutoZone and test the fuel pressure?
Old Jan 16, 2025 | 05:43 PM
ojai150's Avatar
ojai150
very good tip ,…..I had a Ford Taurus that had the impact sensor in the trunk , and more then once it got hit by things in the trunk , just rest it and it was fine
Old Feb 3, 2025 | 07:41 AM
STX Screamer
Still fighting
Update. Still won't start.
I am able to spray starter fluid in the intake and it will start and run as long as I keep giving it the occasional spray. When I stop it dies within a minute.
I had a buddy use a scan tool which claims the fuel pressure is at 4000 psi. Way too high. But the truck still won't start or run on its own. Any thoughts?
Old Feb 3, 2025 | 10:39 AM
SpencerPJ's Avatar
SpencerPJ
Have you considered bad gas? or someone sabotaged you and added water or other to the tank? I'd be almost certain if you got a dongle, and installed Forscan on your phone or preferably laptop, there would be a code stored. imo
Old Feb 3, 2025 | 12:49 PM
GlueGuy's Avatar
GlueGuy
Possibly mis-reading the gauge. Fuel rail pressure typically ranges from 300 PSI at idle to 2200 PSI at full load for a direct-injection engine. If the engine also has port-injection, then I would expect a fraction of that during idle.
bullnosebuford
13
Jun 12, 2023 07:13 AM
Yukon
May 7, 2014 10:51 AM
rblaine9000
Nov 11, 2008 06:00 PM
hatter03
17
Oct 29, 2008 05:07 PM
Bassgetter
Aug 24, 2004 03:20 AM
