Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1962 c600 ford emblems
Old Jan 9, 2025 | 10:38 PM
Shh1966's Avatar
Shh1966
Trailering
Looking for the chrome ford letters on the front of a 1962 ford c600 like these
Old Jan 10, 2025 | 06:27 AM
Shh1966's Avatar
Shh1966
Trailering
Also trying to decode this vin
Old Jan 10, 2025 | 03:36 PM
85e150's Avatar
85e150
Later today.....
Old Jan 10, 2025 | 07:42 PM
85e150's Avatar
85e150
C60 = C600 gas
C = 292 2V Medium Duty Ford Y-block, 135 certified net HP @ 3800 RPM
U = Louisville Assembly Plant
221297 = 1962 numerical series, October 1961 production
135 = 135 inch wheelbase
JM
J = Monte Carlo Red or Rangoon Red (which you can see under the paint below the warranty plate)
M = Corinthian White
C600 = C600 gas, 19,500 lbs GVWR
F = Warner model T98A four speed transmission
E2 = Eaton two speed rear axle, 14,000 lbs capacity, 6.33 / 8.81 ratios. Unsure on model. It will have number cast or stamped into the pumpkin above the pinion and on the driver side front of the axle housing.
No front axle code. It should be a Ford axle with at least 5,500 lbs capacity without power steering
19500 = 19,500 lbs GVWR
135 3800 = 135 certified net HP @ 3800 RPM
No DSO shown, so the area it was originally sold is unknown unless you find a build sheet in the upholstery or elsewhere.
Old Jan 10, 2025 | 09:19 PM
Shh1966's Avatar
Shh1966
Trailering
Thank you so much
Old Feb 28, 2025 | 03:01 PM
Shh1966's Avatar
Shh1966
Trailering
Anybody have any of these they would be willing to part with?
Old Feb 28, 2025 | 08:01 PM
asavage's Avatar
asavage
FTE Community Team
That might be tough. Do you know if those letters interchange with other Ford models?
These all "look" really similar to the design you need, though they're not called out by the sellers as for the C-Series.
https://www.ebay.com/itm/286053386519
https://www.ebay.com/itm/146287936699
https://www.ebay.com/itm/116370785105
Old Feb 28, 2025 | 08:59 PM
Shh1966's Avatar
Shh1966
Trailering
Not sure what they interchange with
Old Mar 6, 2025 | 09:08 PM
Shh1966's Avatar
Shh1966
Trailering
Found some. Thank you everyone
Victor.
Large Truck
Feb 15, 2023 12:12 AM
Drew Smith
Large Truck
Nov 29, 2021 12:42 AM
1949Red
Apr 15, 2021 11:01 AM
Chad Hartley
Jul 13, 2018 11:07 PM
