Starter mounting problem
Old Jan 4, 2025 | 09:47 PM
Lt.superflail's Avatar
Lt.superflail
2nd Gear
So I have 1986 ford ranger that I need to replace the bell housing and I don't know how to go about it or if it's replaceable.
Old Jan 5, 2025 | 01:56 AM
1949f1's Avatar
1949f1
You need to remove the transmission first and the bell housing can be unbolted from it once you remove it. What is wrong with the bell housing
Old Jan 5, 2025 | 12:39 PM
Lt.superflail
2nd Gear
Thank you. One of my friends took it upon him self to try and fix the starter mounts after he stripped them and just making them bigger and bigger to where no size bill will fit and have the starter align with the fly wheel
Old Jan 14, 2025 | 11:20 AM
G2IC_Wraith's Avatar
G2IC_Wraith
This is going off memory since I haven't had my Ranger for a number of years, but IIRC there were 2 different trans if you had a manual. IDK about the auto options.
These trucks had a 1 piece manual trans that Mazda designed & the other was a Mitsubishi trans that "I think" had a removable bell housing.
You didn't say if you have an auto or manual, but assuming you have a manual:
You might be able to save the holes with some HeliCoil inserts, but if they are too far gone then that option has passed.
If the holes are FUBAR, both the Mazda & Mitsu will have to be pulled completely out to correct the issue & it is possible to do it in the driveway but it isn't for the faint of heart.
The trans is awkward & heavy & difficult to do it yourself & your biggest issue may be getting the truck up high enough to be able to get the bell housing/trans out from under the frame rails. I know, cuz I did it to mine in the driveway.
For the Mazda, you will be replacing the whole trans as it is 1 piece.
If it has the 2 piece Mitsu then you could replace the bell housing once it's on the ground.
BTW - "good friend".....
lifted77f250
16
May 22, 2009 06:20 PM
bradbruder33
Nov 28, 2008 12:52 AM
toolz_not_toyz
Jul 22, 2004 02:58 PM
garlicdude
May 1, 2004 11:02 AM
57fordsrule
Sep 6, 2003 03:22 PM
