Cracked Starter Housing
Old May 22, 2009 | 05:32 AM
lifted77f250's Avatar
lifted77f250
I went to start my truck this morning and the start would turnover, but was't engaging. I looked under the truck and the housing cracked on the starter. I have two questions for you guys.
1. What would cause the starter housing to crack? I checked the bolts on the starter alittle over a month ago when I was changing my oil and they were tight.
2. Where should I purchase a new starter from? I really need one today so mail order probably isn't going to work.
Thanks in advance.
Old May 22, 2009 | 06:22 AM
makomaker's Avatar
makomaker
sometimes the the shaft breaks and the next time you hit it, it will crack the housing, it'll just engage the back oof the housing b/c there's so much torque...you should be able to find a replacement at any of the box stores, but be prepared...you won't get a core credit b/c yours is cracked.
Old May 22, 2009 | 07:21 AM
Ponyboychris's Avatar
Ponyboychris
When I called around the auto parts chains in my area, they wanted some serious coin for their rebuilds. Be prepared for sticker shock.
Old May 22, 2009 | 07:31 AM
big poppa's Avatar
big poppa
O boy, seem's everything starts in 2's, now its the starters that the main topic recently. Chris, are you too upset to mention???
Old May 22, 2009 | 07:50 AM
megawatt00's Avatar
megawatt00
Around the $200 mark at NAPA
NAPAONLINE
The friggen core charge on the rebuilts is nuts!
Old May 22, 2009 | 08:01 AM
Ponyboychris
yeah, a bit upset and disappointed...
Old May 22, 2009 | 08:22 AM
big poppa's Avatar
big poppa
I here ya Chris, feel bad for you..Don't like to see that happen to anybody but it does happen, hope it works out for you.
Old May 22, 2009 | 08:52 AM
vettdvr's Avatar
vettdvr
Can't help but wonder??? Should the starters be pulled and rebuilt before failure? 100000 miles or more? Just a thought.
Old May 22, 2009 | 10:09 AM
Tom S's Avatar
Tom S
I have a new motorcraft one here that needs a new home.
Old May 22, 2009 | 10:12 AM
lifted77f250
Well its worse than I originally thought. It turns out the block adapter broke, which in return cause the starter to crack. I wish it was only a starter, now I have to puul the trans to to change the adapter. What a wonderful weekend its going to be!
Anyone ever change this before?
Old May 22, 2009 | 11:00 AM
vettdvr's Avatar
vettdvr
That is what I was afraid of. Yes I have heard of it but not experienced it. Best of luck on a lot of heavy work. Be careful the tranny is about 500#'s.
Old May 22, 2009 | 01:36 PM
lifted77f250
I found the adapter plate now I need to get to work. Anyone have suggestions on doing this? If I am unbolting the trans is there anything I should do to it while its out?
Old May 22, 2009 | 02:05 PM
vettdvr's Avatar
vettdvr
I don't know how many miles you have on it, but you might consider replacing the front seal behind the torque converter. I would also drain the torque converter and change the transmission oil.
Old May 22, 2009 | 04:29 PM
lifted77f250
thanks for the advise vettdvr, but I am actually going to have the trans rebuilt. The garage will replace the adapter plate for me, so I kind of will kill two birds at one time. I am just not really up to pulling the trans to replace the adapter. The trans has 120,000 miles on it and it periodically won't go into reverse unless I shift to drive first. Some guys on the forum said it was a sign of the from shaft bearing going bad, which causes the pump to fail.
Hopefully by this time next week it will be fixed.
Old May 22, 2009 | 04:43 PM
big poppa's Avatar
big poppa
Good luck and let us know how you make out. Are you going to up grade a bit in the trans for peace of mind, just wondering???
