Single spindle nut
Old Dec 27, 2024 | 06:38 AM
My4Fordtrucks's Avatar
My4Fordtrucks
If the snap ring on the axle shaft was against the spindle nut that is wrong. Is the stub shaft not sticking out far enough for you to install the snap ring? If that is the case then you need to reach in from the back of the knuckle and push the shaft outboard with your hand or a large screwdriver/prybar. As I said, changing to the two nut style is pointless. Everything from the spindle nut out is identical on both spindle nut designs.
Old Dec 27, 2024 | 06:51 AM
brandobronco's Avatar
brandobronco
I thought so. I will try pushing it outboard. It wasn’t coming out far enough no. I could pull it out a little bit but still wasn’t out far enough to put that snap ring on.
Old Dec 27, 2024 | 08:35 AM
manicmechanic007's Avatar
manicmechanic007
You just take a big screwdriver from back behind and push the stub shaft out
Pry against the axle housing and the mud slinger on the stub shaft
If you have greased the spindle bearing properly, you'll hear the excess grease squish out, then you install the snap ring
Frank Murch
1978 - 1996 Big Bronco
Nov 10, 2014 08:42 PM
poffutt
13
Nov 27, 2008 05:55 PM
savagefan
May 24, 2006 06:24 PM
gatesj
Offroad & 4x4
Sep 28, 2004 01:03 PM
garypettengill
Garage & Workshop
Aug 20, 2002 01:14 AM
