Cold start normality???
Old Dec 22, 2024 | 07:20 PM
Iszy131's Avatar
Iszy131
I have a F100 1978 Ranger 302 c6, when i start my truck i have to leave foot slightly on gas or it will turn off is this normal??? Also when i try to punch it it like hesitates then hauls once in a while it will turn off??
Old Dec 22, 2024 | 07:29 PM
mterickson's Avatar
mterickson
When you go to start it you should be pumping the pedal at least once, but usually a few times. This does two things, one it sets the choke and actuates the fast idle cam, and of course pumps some fuel into the intake to help it fire.
If you are doing that and you still need to hold the throttle to keep it from stalling it sounds like your fast idle speed and possible the choke plate need adjustment. Even if you have adjusted before, with a carb vehicle you'll need to do these adjustments a couple or more times a year depending on how dramatically your seasons change.
They are not at all going to run like a fuel injected vehicle that you can just jump in turn the key and drive off.
You'll find every carb vehicle out there has it's own personality and "special combination" to fire up easily. Once you figure out the combo for your vehicle you'll be able to jump in and get it fired right up.
Fuel/air mixture, curb idle speed and ignition timing will all need occasional adjustment throughout the year for your truck to run optimally.
Old Dec 23, 2024 | 12:53 PM
Iszy131's Avatar
Iszy131
i will try that, i was not aware of having to adjust more than 1 time thank you
Old Dec 23, 2024 | 01:29 PM
Iszy131's Avatar
Iszy131
FYI i only leave throttle pushed alil for like 30 seconds to a minute then it stays on by itself
the almighty schmuck
Jul 20, 2011 09:18 PM
RussellF
Jan 16, 2009 10:26 AM
VSneader2
1983 - 2012 Ranger & B-Series
17
Dec 29, 2005 06:43 AM
777tcsrdb
Oct 5, 2004 07:53 PM
TallPaul
Aug 23, 2002 03:02 PM
