Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
VIN decoder
Old Dec 14, 2024 | 06:45 PM
tkalb's Avatar
tkalb
8th Gear
VIN decoder
I acquired what I was told is a 1969 950 super duty. I can’t find anything about the truck I have. Has duals in the back I’ve never seen except for a dump, but I have a different body style. Please let me know what I have. I know nothing about it or “N” series trucks. I can’t wait to get this running!
Old Dec 14, 2024 | 07:59 PM
85e150's Avatar
85e150
I'll get back to you later. You do realize this is a CDL truck? What are your plans for it?
Old Dec 14, 2024 | 08:53 PM
tkalb's Avatar
tkalb
8th Gear
Yes. I currently hold a Class A with hazmat. I plan to use it for my beekeeping hobby and haul stuff. I have a trailer I would like to weld to it.
Old Dec 14, 2024 | 08:58 PM
85e150's Avatar
85e150
S95 = NT950 gas
K = 477 4V Super Duty gas V8
U = Louisville Assembly Plant
G11066 = 1969 numerical series, late in production as numbers ended in the G30xxx range per the MPC.
146 = 146 inch wheelbase
No color code. This appears to be red, which, if original, would be a standard color. But no code indicates color was part of the special order.
S950 = NT950 gas, 47,000 lbs GVWR
4B81
4B = Black Leather Grain Vinyl
81 = 81A, standard cab, cab and chassis vehicle
C = Fuller model RT-510 ten speed direct transmission
D5E
D5 = Rockwell model SQHD Hendrickson tandem rear axles, 38,000 lbs capacity, 5.83 ratio
E = Ford-Rockwell (Timken) 9,000 lb capacity front axle without hydraulic brakes.
47000 = 47,000 lbs GVWR
222 3200 = 222 Certified Net HP @ 3200 RPM
158447
15 = Newark District Sales Office
8447 = Special Order Number
Old Dec 14, 2024 | 09:15 PM
tkalb's Avatar
tkalb
8th Gear
Thank you so much! Was the dually standard or special order. Haven’t seen a gasser with a duals.
Old Dec 14, 2024 | 11:29 PM
85e150's Avatar
85e150
Is it a runner?
Old Dec 14, 2024 | 11:53 PM
85e150's Avatar
85e150
The truck series and model indicate it's a tandem axle truck. In '69 there were few, if any, super single setups. Thus, all medium and heavy trucks were DRW. Not all were tandem, but there were tandem axle models going back into the '50s.
The tandem trucks were designated with a "T". They started at the 700 level, so you have T700 or T800 etc, that are F series trucks with tandem axles. The N series started in '63 and offered the NT850 and 950 under the S85 and S95 series numbers. U85 & 95 were T850/950 diesels, and W85/95 were NT 850/950 diesels.
I don't know production numbers, but Ford sold a bunch of tandems. Including going back to the F series (600s I think) "rubber band drive" models with a regular live axle connected via belts between to duals to a dead tag axle.
Old Dec 15, 2024 | 08:07 AM
tkalb's Avatar
tkalb
8th Gear
Wow thanks, didn’t know that. I obviously have more research to do! It’s not running right now, unless “runner” means something else?
Old Dec 15, 2024 | 07:36 PM
85e150's Avatar
85e150
If it's not running, this will be a good run through to see how easy/hard it is to get parts for the Super Duty V8. Tune up parts like cap, rotor, points and wires are the same as any other Ford V8, as long as you get wires for a larger engine. Timing is 6 degrees. Idle circuits might be on the rear block of the carb as the carb should have a governor.
Carb kit can be found with the list number on the choke housing.
Old Dec 15, 2024 | 10:12 PM
tkalb's Avatar
tkalb
8th Gear
Ya, I’m hoping a very basic tune up could just get it up and running. Then I can work on more replacing/repairing.
jvburris
Large Truck
Jul 22, 2024 10:47 PM
hoyt1995
Large Truck
Mar 25, 2024 03:52 PM
ymountainman
Large Truck
Feb 14, 2022 06:44 PM
Drew Smith
Large Truck
Nov 29, 2021 12:42 AM
JakeK
Mar 4, 2018 05:59 PM
