bed light install issue
Old Dec 16, 2024 | 09:03 AM
diablos's Avatar
diablos
Originally Posted by ZooDad
@diablos
Do you have “Lincoln Experience” enabled by chance ?
ZooDad
first ive heard of that, so guessing no.
in addition to the wiring possibility above (want to avoid that), i've been reading about how sensitive these new trucks are to low voltage/how the bcm will turn things off if there is (what id consider), minimal voltage drop. suggestion was to either pull the negative terminal to reset bcm (but doesnt forscan do that during the write process?), or start the truck to get the voltage up (it has sat for a week or so)
Old Dec 16, 2024 | 09:25 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
@diablos
Ok good. No ForScan does not reboot the BdyCm on write, but you can do exactly that in service procedures.
I will take a look at your screenshot and compare see if I see anything obvious.
If not I may need more data to work with.
ZooDad
Old Dec 16, 2024 | 10:33 AM
diablos's Avatar
diablos
lincoln is for sure disabled, i also performed the bcm reset in systems procedures. no change in symptoms
quick edit
also put battery tender on it, test the "low voltage" theory
forscan pic for those that may encounter this issue
Old Dec 16, 2024 | 12:38 PM
diablos's Avatar
diablos
*not a forscan issue*
did some troubleshooting with limitless and as i was backprobing to test for voltage at the connector under the truck the lights started working (?). as soon as i removed the probe..lights out. so i removed the white loom cover and hooked the connector back together, lights work perfect. so there is an issue with how the connector is seating. will check it after work and report back.
Old Dec 16, 2024 | 12:51 PM
ZooDad's Avatar
ZooDad
Limitless is top notch both in product and support.
Glad you got it figured out
ZooDad
Old Dec 16, 2024 | 02:23 PM
HorizontalHunter's Avatar
HorizontalHunter
Glad that you got it figured out.
Bob
Pkusa
May 28, 2023 11:08 AM
comptechltd
Sep 19, 2022 08:41 PM
Doug Savage
Sep 28, 2021 01:14 PM
mrrish79
2009 - 2014 F150
Apr 29, 2015 05:35 PM
Catfish_Man
Dec 29, 2009 08:47 PM
