installed the kit from limitless, and did forscan programming according to their procedures for 2021. lights dont work, but rear cab light does. what did i do wrong?
heres' what i input into forscan, its supposed to be correct per the directions and what i dug up here on the forscan spreadsheet. i hit write after each change and cycled the key after the final change. not sure what i would've done wrong or need to change.
What year and model truck?
Check the forscan spread sheet that covers your year and model truck. If memory serves you need to make changes to two modules to enable the bed lights. It has been awhile since I looked into it for a friend. You can also check with @ZooDad .
Bob
2021 xlt (blis non-led) i made those changes in the bcm "as built" module but did see bed lamp setting available as well.
correct, im going to pull the connection apart to verify its seated and no debris is in it
Generally that means that the wiring is good and it’s a programming issue. I would try to reprogram in case it didn’t take. I tagged zoodad so hopefully he will pop in as he is the resident Forescan expert.
Other than that I would call Limitless tomorrow and see what they suggest.
Bob
wanted to address this real quick, i did go in and check the lines to make sure i had the correct "1's and 2's " in the proper places and when i tried to write forscan said no changes were made, i forced wrote just to make sure. still no bed lights.
