7.3 flow plug relay issue
Old Dec 14, 2024 | 03:01 PM
cuttn4fun's Avatar
cuttn4fun
I just replaced my gpr with the ultimate one from diesel orings. I cannot get it to turn on. I have good voltage on the constant hot. The two small termials show voltage. 1 has 12.5v the opposite side one drops to 10.8ish key on. I tried to ground the orange wire and when it's grounded the gpr does turn on and stay on even after removal of the jumper wire. After it does power up even after the 2min mark it stays on continuous until I power the key off. Upon turning key back on gpr does not turn on until the jumper is placed on it again. This is in 30ish temps and cold engine so the gpr should definitely be wanting to power up.
I have the led light to show when gpr is on. It's connected to the big wire that powers glo plugs.
Any advice or insight? thanks in advance.
Edit.
This is a 2003 f250 with the 7.3 diesel. I have had this truck for about 12 or 13 years and glow plugs were changed 6 years ago. Never been an issue until last year. I figured bad replay but just kept plugging truck up to get it to start.
Old Dec 14, 2024 | 05:36 PM
Wes444's Avatar
Wes444
Not sure about that brand of relay. The PCM grounds the small lug to activate the glow plugs. Voltage on it is bad for the PCM.
I use the Trombetta one after replacing the Motorcraft every 5-6 years
Old Dec 14, 2024 | 05:57 PM
tjc transport's Avatar
tjc transport
i ain't rite
there will always be power to one of the small terminals with key on. the PCM grounds the glow plug relay. so if your relay is not getting ground signal, the glow plug circuit in your PCM is bad, or the wire going to the GPR is bad.
Old Dec 14, 2024 | 06:14 PM
cuttn4fun's Avatar
cuttn4fun
this is what I was thinking. Both small sides show voltage when key is on.. the one side shows 12v the other side 10ish volts. I may have to wire a push button into it to ground the one terminal.
Old Dec 14, 2024 | 06:31 PM
Pikachu's Avatar
Pikachu
You did disconnect them to take voltage readings, right?
Old Dec 14, 2024 | 09:12 PM
cuttn4fun's Avatar
cuttn4fun
I did not. I checked the voltages on old one and new one with them connected to the gpr.
Old Dec 15, 2024 | 07:05 AM
Pikachu's Avatar
Pikachu
That's why you're seeing voltage on both of the small wires. The 12v constant wire is just feeding voltage through the relay coil. Disconnect the small wires, connect your meter probes to them and see if there's voltage there at key on.
Old Dec 15, 2024 | 07:24 AM
cuttn4fun's Avatar
cuttn4fun
I will try that. I did not see the part about not having the small wires connected prior to testing with the meter.
the gpr I used is the Stancor bought from diesel orings.
thanks for yalls input.
Lockholder
16
Dec 10, 2018 08:52 PM
Carl Brown
25
Feb 21, 2013 06:51 PM
Oldsmoky92
20
Feb 28, 2012 09:06 AM
ex-wolverine
May 15, 2010 05:57 PM
wyattwie
May 7, 2010 09:12 PM
