If you have 12v to one small wire then the other small wire (ground) has a break in it. If no 12v then you have a break in it. The small key on hot comes from fuse #22
Alright i checked for power on the little wires and neither had any. I can see the harness wires under the air box are all visibly not protected by the the black wrinkle tubing. I am going to pull air box and probably throw it away in the process and inspect harness. I despise the factory air box!
Indeed the stock airbox is cr@p. But do you have something else lined up to replace it, such as a 6637 or other "big barrel" filter?
Lack of power at the red/green small wire is at the crux of your problem. Just so we're on the same page, you did check it with the key in RUN, correct? If so, and if you indeed have the WTS light, then the problem is most likely a break in that wire, somewhere between the GP relay and the PCM.
