I've got a 2003 F350 6.0L 6SPD Studded with SCTX4 Tuner
So when the truck is ice cold in the morning it idles perfectly normal but when it up to operating temperature I Misses and you can hear kind of a choppy sound during vgt cycle. But going down the road when its cold it stutters and jerks a little bit. And then going down road at operating temps it's perfect fine.
Has new HPOP, Injectors, FICM and FICM pigtails.
Took out and cleaned out the EGR valve ICP data stream looks good.
The only way for people to help is for you to provide both codes and data. And the best and cheapest way to do that is using Forscan or torque pro with an OBD2 adapter. There are many threads here and other forums, or just do a Google search for finding out the best way to do that. I’m a little tied up selling Christmas trees right now so I can’t go into it
Take a look at this pinned thread. It will help get you started on what information will be needed along with the tools you'll need to get that data for the folks here that can help.
Well currently I'm throwing any codes. I have forscan and torque pro, but Ive been useing my diesel laptops handled on it.
