P0381 code, new GPCM?
Old Dec 6, 2024 | 02:42 PM
7.3Xcursion's Avatar
7.3Xcursion
Hi all,
I got a SES light on my dash the other day. I pulled the codes and got a P0381 and a P0603. Forscan shows
===PCM DTC P0381===
Code: P0381 - Glowplug lamp circuit
Module: Powertrain Control Module
Diagnostic Trouble Code details
This DTC may be caused by :
Open circuit.
Short circuit
Possible causes are:
Harness wiring
Indicator bulb
PCM
Inspect connectors for signs of damage, water ingress, corrosion, etc.
I'm assuming this means I need a new GPCM, correct?
Old Dec 6, 2024 | 05:32 PM
01__Excursion's Avatar
01__Excursion
This means you need to diagnose the issue, based on the suggestions given.
Old Dec 6, 2024 | 06:43 PM
7.3Xcursion
I didn't know if there was a common issue with the GPCM, or if there was a common cause for the code. If there is, I'd start there before diving down the rabbit hole of diagnosing everything.
Old Dec 7, 2024 | 11:03 AM
corpsedub's Avatar
corpsedub
It has been seen that the square connectors to the gpcm can get...fried. have you looked at the connectors and the harness around the gpcm?
Listor
Dec 16, 2022 07:35 AM
wyoclint
Dec 15, 2016 05:02 PM
grldben
Aug 4, 2013 08:45 PM
whybnormal
Nov 22, 2007 06:37 AM
ALF1999
Oct 29, 2005 06:13 PM
