having issues codes 121,212,332.
Old Aug 4, 2013 | 06:09 AM
grldben's Avatar
grldben
121 koeo 212,332 cm need help please
Old Aug 4, 2013 | 07:46 AM
rla2005's Avatar
rla2005
KOEO Code 121: Closed throttle TPS voltage higher or lower than expected.
Use a meter to verify the output at closed throttle. Reference:Fuel Injection Technical Library » Throttle Position Sensor (TPS)
CM Code 212: Loss of IDM input to EEC or SPOUT circuit grounded.
DTC 212 indicates a loss of IDM input to the PCM.
Possible causes:
-- Open harness circuit.
-- Shorted harness circuit.
-- Damaged or incorrect Ignition Control Module (ICM).
-- Damaged Powertrain Control Module (PCM).
CM Code 332: EGR valve opening not detected.
What year/model/engine truck do you have?
What issues are you trying to resolve?
Old Aug 4, 2013 | 07:07 PM
grldben's Avatar
grldben
I may have found the 212 i have a gray icm someone on here said it should be black havnt gotten the part yet what do you think the 121 code was my tps change it and code is gone egr code im still not sure about.
Old Aug 4, 2013 | 07:30 PM
rla2005's Avatar
rla2005
Old Aug 4, 2013 | 08:45 PM
grldben's Avatar
grldben
91 f-150 xlt lariat 2wheel drive 4.9 liter automatic
wyoclint
Dec 15, 2016 05:02 PM
Carl Futch
Feb 18, 2016 04:53 PM
CarCrazyRDM
Jan 29, 2011 07:53 AM
Redneck1465
Feb 8, 2010 09:05 PM
ALF1999
Oct 29, 2005 06:13 PM
