Rough idle help needed
Old Dec 12, 2016 | 11:42 AM
wyoclint's Avatar
wyoclint
4wd Low
2002. Starts easy enough, runs horrible, really rough and lots of white smoke. Will die if left unattended, doesnt matter if its plugged in or not. GPR was bad, replaced. Checked all glow plugs, all at .6-.8. After I start it, if I give it some throttle, I can get it past the rough running enough to get it going. Then I pretty much have to drive it and throttle it through a couple of gears and it clears out and runs fine.
Thank you for your help!
EDIT: I cleared the codes on it yesterday with code reader I picked up. Ran codes on it this morning after I got home. Here is what was pulled from Forscan. The water in fuel sensor is bad (got one on order). No matter how much I drain it comes back on, so assuming its bad anyway
===OBDII DTC None===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===IC DTC U1027===
Code: U1027 - Engine RPM Data Invalid
Module: Instrument Cluster
Diagnostic Trouble Code details
At some time in the past a corrupt message was received from the PCM. Try clearing the DTC to see if this DTC re occurs. If it does then carefully check the SCP wiring and run the PCM diagnostic.
===END IC DTC U1027===
===IC DTC B1352===
Code: B1352 - Ignition key in circuit fault
--- Possible Causes --------
This DTC can be generated by:
-Open Key-In Ignition Switch circuit
- Battery short Key-In Ignition Switch circuit
- Battery short Ignition Switch RUN/ACCY circuit
- Suspect Ignition Switch
- Suspect Lighting Control Module.
===END IC DTC B1352===
===IC DTC U1262===
Code: U1262 - SCP Data Link Fault
SCP Data Link Fault
Operator Action
Run self test.
All CMDTCs
Fix all relevant DTCs then clear codes and retest.
Note:
DTCs that start with 'U' are faults which occur during module-to-module communication.
Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle.
===END IC DTC U1262===
===PCM DTC P1280===
Code: P1280 - Injector Control Pressure Failure
Module: Powertrain Control Module
Injector Control Pressure (ICP) circuit out of range low.
--Possible Causes--
- Open or grounded ICP circuit.
- Open VREF circuit.
- Damaged ICP sensor.
- Damaged PCM.
===END PCM DTC P1280===
===PCM DTC P0472===
Code: P0472 - Exhaust Pressure Sensor Low Input
This DTC may be caused by :
Open circuit.
Short to Ground
Possible causes are:
Harness wiring
EBP sensor
PCM
Inspect connectors for signs of damage, water ingress, corrosion, etc.
===END PCM DTC P0472===
===PCM DTC P0118===
Code: P0118 - ECT Sensor Circuit High Input
Sensor Previously disconnected.
Damaged or contaminated connector
Improper connection
Incorrect VREF.
Signal shorted to VBATT or vref.
Open Circuit
SIGRTN open circuit
Suspect ECT sensor.
Faulty or damaged PCM.
===END PCM DTC P0118===
===PCM DTC P0198===
Code: P0198 - Engine Oil Temperature Sensor Circuit High Input
Engine Oil Temperature(EOT) circuit out of range high.
--Possible Causes--
- Open circuit.
- Short to VREF.
- Damaged sensor.
- Damaged PCM.
===END PCM DTC P0198===
===PCM DTC P1119===
Code: P1119 - Manifold Air Temperature Circuit High Input
Open circuit.
Short to power
Harness wiring
Manifold air intake temperature sensor.
PCM
===END PCM DTC P1119===
===PCM DTC P1140===
Code: P1140 - Water in Fuel Condition
Short to Ground
Harness wiring
PCM
WIF Sensor
===END PCM DTC P1140===
===PCM DTC P0475===
Code: P0475 - Exhaust pressure control valve malfunction
Exhaust pressure control valve malfunction.
--Possible Causes--
- Short to power.
- Open or grounded circuit.
- Damaged solenoid.
- Damaged PCM.
===END PCM DTC P0475===
===PCM DTC P0541===
Code: P0541 - Manifold Intake Air Heater Circuit Low
Open circuit.
Short to Ground
Harness wiring
MIAH Relay
PCM
Old Dec 12, 2016 | 10:04 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Lots of seemingly unrelated codes. These are the ones that came back?
I'd leave the WIF sensor wire disconnected and taped out of the way for now.
First item I'd check is the engine harness where it crosses the driver side valve cover en route to the 42 pin connector. Pull apart and look underneath for chafing and resulting short to ground on the VC.
While there pop the wire off the ICP sensor and look for oil. If wet replace with OEM Ford or IH, not aftermarket. The cheapies tend to have problems.
How much fuel in the tank? 1/4 or less can be a problem.
The rough running, dying and white smoke sound like fuel starvation. But if it clears up and runs normally after some driving that sounds like a clog on the in tank screens clearing off due to sloshing. A fuel pressure gauge monitored while operating would be best. Barring that observe the fuel volume from the fuel bowl drain. When running bad, turn off and key fuel pump back on (do not start) and watch flow into clean container so you can put it back. A helper to key on is needed there as pump will only run for 20 seconds unless engine starts. Do same visual check when running well.
How long has it been doing this?
Old Dec 13, 2016 | 01:05 PM
wyoclint's Avatar
wyoclint
4wd Low
Only recently. Ill check ICP today and wiring harness. If I can get the help Ill check the fuel. I drove it a few more times yesterday after clearning the codes. Ill pull codes before starting it today and see if they come back. I recently replaced the ICP sensor. I read that I should check the wiring for oil and then clean it if there is, so Ill check that as well.
It has about 1/4 tank in it. Ill fill it up.
Would a video of starting it help?
Old Dec 13, 2016 | 01:23 PM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
The P1280 code almost always indicates a bad ICP sensor. As stated, pop the connector off and look for oil. If it is wet, replace it. Even if it is not wet, having a P1280 code would make me want to replace it anyway.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Dec 13, 2016 | 06:08 PM
wyoclint's Avatar
wyoclint
4wd Low
Since I put a new one on it a couple months ago, I checked it. The harness plug had oil in it, so I sprayed it out and and put it back together.
Started great! a little white smoke, but good idle and warmed up and ran fine.
Ran codes and am getting all kinds of strange stuff.
Do these codes go back to a PCM failure or do I need to go ahead and pull the harness apart on driver vc and inspect? Ive never seen it come up with these.
Thank you all for your help! Its running good, but I wanna figure out the rest of this.
I forgot to include Im running a DP tuner F5 on it. I should have put that in my first post...
Code: P1536 - Parking Brake Switch Circuit
Follow the routines in the service manual to resolve the DTC listed.
===END DTC P1536===
===DTC P0220===
Code: P0220 - TP - B sensor/switch malfunction
Open circuit.
Short to power
Harness wiring
Idle Validation Switch
PCM
===END DTC P0220===
===DTC P0704===
Code: P0704 - Clutch switch input circuit malfunction
Shorted to power.
Suspect Clutch Pedal Position switch.
Suspect PCM.
===END DTC P0704===
===DTC P0571===
Code: P0571 - Speed Control Brake switch circuit failure
Brake switch circuit malfunction.
--Possible Causes--
- Operator intervention error.
- Open, short to B+ or GND in BPA circuit between PCM and switch.
- Open or short to GND between switch and power.
- Blown fuse.
- Damaged switch.
- Damaged PCM.
Note: Code will set if vehicle is not equipped with cruise control.
===END DTC P0571===
===DTC P0703===
Code: P0703 - BOO switch circuit fault
Brake Switch B Input Circuit
Open circuit.
Short to power
Harness wiring
Brake Switch
PCM
===END DTC P0703===
===DTC P0565===
Code: P0565 - Cruise control on signal malfunction
===END DTC P0565===
===DTC P0566===
Code: P0566 - Cruise Control OFF Signal
===END DTC P0566===
===DTC P0567===
Code: P0567 - Cruise Control RESUME Signal
===END DTC P0567===
===DTC P0568===
Code: P0568 - Cruise Control SET Signal
===END DTC P0568===
===DTC P0569===
Code: P0569 - Cruise Control COAST Signal
Cruise (COAST) signal malfunction.
--Possible Causes--
- Worn or damaged speed control switch.
- Open, grounded, or short to power in SCCS circuit.
- Open or short in SC GND circuit.
- Open in Power supply circuit.
- Damaged PCM.
===END DTC P0569===
===DTC P0541===
Open circuit.
Short to Ground
Harness wiring
MIAH Relay
PCM
===END DTC P0541===
Old Dec 13, 2016 | 06:25 PM
Justin@DP-Tuner
PREMIUM SPONSOR
===END DTC P1536===
===DTC P0220===
Open circuit.
Short to power
Harness wiring
PCM
===END DTC P0220===
===DTC P0704===
Shorted to power.
Suspect PCM.
===END DTC P0704===
===DTC P0571===
--Possible Causes--
- Blown fuse.
- Damaged switch.
- Damaged PCM.
===END DTC P0571===
===DTC P0703===
Open circuit.
Short to power
Harness wiring
Brake Switch
PCM
===END DTC P0703===
===DTC P0565===
===END DTC P0565===
===DTC P0566===
===END DTC P0566===
===DTC P0567===
===END DTC P0567===
===DTC P0568===
===END DTC P0568===
===DTC P0569===
--Possible Causes--
- Damaged PCM.
===END DTC P0569===
===DTC P0541===
Open circuit.
Short to Ground
Harness wiring
MIAH Relay
PCM
===END DTC P0541===
Glad to hear it is running better.
All of those codes are pretty random and not seen often. If it is running and driving well, I would not suspect your PCM is bad.
A lot of the codes you listed have to do with the cruise control. Is everything working fine there?
__________________
Justin
www.dp-tuner.com
Old Dec 13, 2016 | 06:31 PM
wyoclint's Avatar
wyoclint
4wd Low
Ill drive it tomorrow, but yeah, everything has been working fine on it. Ill check the cruise, but it worked fine last week when I used it.
Old Dec 13, 2016 | 07:00 PM
Justin@DP-Tuner
PREMIUM SPONSOR
When was the last time you cleared all the codes? If you haven't in a while, do that first and then go drive it to see if they return.
__________________
Justin
www.dp-tuner.com
Old Dec 14, 2016 | 09:39 PM
wyoclint's Avatar
wyoclint
4wd Low
Cleared them out. Here is what I have now. I just put milemarker hubs on it as the 4wd wouldnt engage on its own. Not sure if I need to worry about that code?
===OBDII DTC ===
===END OBDII===
===IC DTC U1262===
SCP Data Link Fault
Operator Action
Run self test.
All CMDTCs
Note:
===END IC===
===PCM DTC P1140===
Short to Ground
Harness wiring
PCM
WIF Sensor
===END PCM===
===RCM DTC ===
Module: Restraint Control Module
===END RCM===
===GEM DTC P1876===
Code: P1876 - Transfer Case 2-Wheel Drive Solenoid Circuit Open Or Short To Ground
Module: Generic Electronic Module
===END GEM===
===ABS DTC ===
Module: Anti-Lock Brake / Traction Control Module
===END ABS===
Old Dec 15, 2016 | 09:18 AM
MoBill122's Avatar
MoBill122
Papa Smurf
You have so much going on here.... so much random... I would look at the big wiring connector on driver's side of engine. Clean the connector. Then follow the big bundle of wires back to the plugs under the brake master cylinder.... look for a place wiring could be grounding out. Check your engine grounding terminals...pcm ground, etc.
Old Dec 15, 2016 | 10:43 AM
wyoclint's Avatar
wyoclint
4wd Low
Well, I checked as much as I could find, everything is in good shape. I havent gotten the cruise control stuff back, everything is working.
I know the WIF is valid, and the 2wd/4wd is valid as I would have to manually turn in the stock "hubs" when I put it in 4wd or it wouldnt engage.
Im gonna run it for a few days and check codes and see if anything comes back. After two days of running, the smoke and rough start is gone.
Old Dec 15, 2016 | 05:02 PM
MoBill122's Avatar
MoBill122
Papa Smurf
Cruise.... the sensor on the brake master cylinder is a known problem. There's a recall on it, as that's the sensor that was burning up a lot of gas burners. Took them years to issue the recall for diesel.... diesel doesn't burn as easy as a gasser... was there reasoning.
Redneckmorton
Feb 27, 2026 12:58 AM
jimjokjv
Aug 2, 2017 06:59 PM
rustyandleaking
Dec 30, 2016 01:16 PM
spyder0382
18
Jul 13, 2014 08:16 PM
Tomget
1983 - 2012 Ranger & B-Series
Sep 18, 2008 11:26 AM
