Transmission issues
To make the later one work, first, it needs to be from a diesel. Then you need to change the torque converter to one that has four studs. Then you need to pull the pump out and reduce one orifice from -.250" to 0.030". If you decide to do this I can find a description of which orifice this is. Next. you need to change the solenoid body to a 1989-1994 E4OD solenoid body. The 2000 transmission will have speed sensors, you can just ignore them. Leave them in the trans to plug the holes in the case.
So just drill it out, easy, and what do I use for a cup plug? Is that something I can get easy or?
Another thing, can I use the converter from the E4OD or do I have to get a different flywheel from a 4r100 truck since it's a 6 bolt conv, the one that came out of it with the e4 was a 4 bolt.
If you haven't done any of this, be sure to say so. We can help you avoid major issues before you start.
This is very advanced trans work. If you need some help, say so before you start.
I've done some trans work. I'ma mechanic daily but never anything super advanced transmission wise atleast on something like this , I can do redo dcts and most manual transmissions but haven't dug super far into auto, I've got a grasp but some detail would be nice. I've got a puller for the pump and all the gaskets, watched a few vids and have a book on e4s, again tho some detail or tips and tricks would be greatly appreciated. Also again what do I use for a cup plug ECT.
Well that's good. So you don't need to be told not to pry against the trans and snap off the cross support, since you have the correct tools to to remove it.
So you'll pull the pan so you can pull the filter.
Be sure the trans is standing on it's tail, before you unbolt the pump, so parts don't fall out. (I've got this t-shirt!)
Split the pump, take note of the pump gears, don't let them fall out.
Do as the instructions say and as Mark instructs to mod the pump.
After the pump has been modified, when you place it back together, you'll notice a lot of play in the bolt holes. Take extra time, to center them by twisting the pump cover to get it just right.
At the same time, you're lining up the bolt holes, you need to very carefully, line up the cover to the pump bottom also. They make a large clamp for this, you can try to find a super large clamp to work, but I found if you really take your time, you can feel all around the two halves, very, very closely and carefully by hand and get it spot on too....but it takes a while. You're not a trans shop where time is money, so just take the time. When both the bolts and the case are centered perfectly, you'll know.......If you don't know, keep feeling and looking until you do.
Once it's back together, it's just a matter of bolting back down in with a new gasket. Just be sure the trans remains up on it's tail the whole time, while the pump is out. Sounds like you got this no problem.
If Mark tells you to rob the plug from your E4OD pump, look it over while it's split. It might be just fine. Lift the gears straight up and look where they ride in the pump housing for any excessive ware. If you don't see any, you might just want to try using your E4OD's pump as it is. If it doesn't look so hot, inspect the 4R100's the same way and if it's good, then go ahead with modding that or replacing the pump with a reman if both are worn hard under the gears.........and if you need to get a reman, get a E40D "F5" pump. It's a '95+ higher volume.
Oh, and the removal of the "TCC valve train". You'll see which ones you'll need to pull out, once the pump is split. Look down into the bore to see which row of valves are in your way, and you'll see on the outside of the pump how to slide them out;
This is just random, I don't remember what I was doing here. Boost valve mod I guess. Keep everything lined up. Then of course if you drill anything down in there, you'll need to spray it out well, but if your getting a plug to put down in there, drill it first (or maybe if you use one from the E4 pump, you wont be drilling at all, just placing it down in anyway?) But point being, don't lose anything and clean up well.
Lastly, I know you said you wanted to keep things tight $ wise......... But you will be right down into it.......Just in case, this is major upgrade:
https://www.ford-trucks.com/forums/1...nd-towing.html
Ok nothing too hard, I'll wait for his response, now can I use the E4OD pump, will it work and shift good, I've read around a little and there's mentions of it shifting super duper hard if you just swap pump? Not sure tho haven't got a direct answer on that. I'll still inspect them but if I don't need to do unnecessary work then I won't lol.
You won't be able to get the cup plug out of the E4OD pump. I think a good trans supply store would have one, but I have never looked for one on it's own. I've purchased kits that had them.
I don't know if the E4OD pump will work or not. I suspect it will, but I don't know for sure.
You don't need to change the flex plate, because as the instructions I posted stated you need to use an E4OD converter, not a 4R100 converter. The lockup clutch is different and the 4R100 converter won't last long in an E4OD system.
I know nothing first hand about this. I've always said, if I were to ever use a 4R100, I would just swap in an E4OD pump, mod it with the trans go tugger kit (not this shown here).
So what im gathering i need to take the e4od solenoid, pump, and converter and throw them in the 4r100 and it'll work In the truck? Right?
