Retainer clips
Old Nov 30, 2024 | 10:08 PM
saauvenshine's Avatar
saauvenshine
Retainer clips
Hey guys have a 1954 ford truck and fixing to put new window and door cranks. The new ones I bought did not come with retainer clips. Went to auto store and bought a pack of dorman assorted clips but none would work. Found some online but for 6 clips (2 extra) clips were just 50 cents each but shipping was $22. Wondering if any of you have found any or have a few I could buy and send a self-addressed envelope to send. It must have to be the exact clip as the ones I bought would not hold handles on the shaft. Thanks
Old Dec 1, 2024 | 04:30 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
A couple of options with much lesser shipping costs:
Amazon Amazon
https://www.ebay.com/itm/145651135785
You can get a 100 pack with delivery for $17... https://car-pak.com/product/car-pak-j0921/
Old Dec 1, 2024 | 09:17 AM
M2HB's Avatar
M2HB
As a follow up question to the OP’s inquiry.
Is there a way to get new shafts for the window cranks and door latches to change them to the 1956 style with the set screw, instead of those frustrating clips?
I have one latch on my 55 that I still cannot get off, even with the tool.
Old Dec 1, 2024 | 10:47 AM
FuzzFace2's Avatar
FuzzFace2
One of the TV shows shows how to get them clips off using a rag, I have always used the tool that I have had since the early 80's
On the rag deal it was something like get the rag between the door and handle holding the rag on either side and then kind of pull it like you were going to polish clean behind the handle and rock the rag so it grabs the clip and pops it off. He showed the rag keep the clip from flying too.
It was on Hot Rod TV or something like that just did not pay that much to it as I got the tool.
Dave ----
Old Dec 1, 2024 | 10:49 AM
ingo's Avatar
ingo
In my opinion, you only need the handles / levers of the 56 with the set screws.
Old Dec 1, 2024 | 12:19 PM
M2HB's Avatar
M2HB
Thanks for the info.
So the 56 set screw handles will work on the 55 shafts.
That is good to know since I certainly will never, ever use those clips again.
Old Dec 1, 2024 | 12:28 PM
ingo's Avatar
ingo
Yes, according to my research, 53-55 & 56 have the same splining. When I got my 56 it had window cranks with clips, as these were worn out I ordered 56 cranks with setscrews, these fitted.
Old Dec 1, 2024 | 01:28 PM
M2HB's Avatar
M2HB
I was concerned that the 56 spines shaft had some kind of a groove to accept the set screw.
The one clip I cannot get off my 55 door does not seem to have any significant ears on it, to push against with the tool.
Eventually, I will get it.
Old Dec 1, 2024 | 01:36 PM
abe's Avatar
abe
Try using a small pick with a slight bend on it and a small flat screwdriver. That's what used for both my trucks with no problems.
Old Dec 1, 2024 | 01:45 PM
bmoran4's Avatar
bmoran4
Just get yourself the tool: https://www.google.com/search?q=dorman+76951
Old Dec 1, 2024 | 07:06 PM
M2HB's Avatar
M2HB
I have the tool and it will not work on this last one.
It appears that there are no, or small, ears on the clip.
emgee
May 13, 2018 02:29 PM
cts1954
Jun 26, 2013 04:53 PM
hotrodbob51
Aug 25, 2012 11:47 PM
Woodsman_30350
Sep 20, 2008 09:10 AM
cbsaf
2004 - 2008 F150
15
Jan 31, 2005 04:58 PM
