What is this?
Old Nov 26, 2024 | 10:25 AM
dcautomotive's Avatar
dcautomotive
4th Gear
What is this?
Can anyone tell me what this is? It is riveted to the blower motor box on our 1976 High Boy body. We are taking a '76 body and put it on a '73 frame. I can't find the those colored wires in any diagrams from '73-'79. I'm hoping someone here known what it is. We are also completely rewiring the truck, so I need to know what wires to connect where. The truck does have AC and the wires were cut by the person that removed the body from the old frame. At first we thought it was the blower resistor, but we found that on the inside of the truck.
Thanks for your help.
Old Nov 26, 2024 | 11:09 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
So that is on top of the (a/c evaporative assembly) evaporator box in the engine compartment. I have never seen anything ever attached there that has elec wiring going to it. Hopefully someone has seen one and can tell us what it is.
Old Nov 26, 2024 | 11:19 AM
Rubiranch's Avatar
Rubiranch
Possible an aftermarket clutch cycling switch to keep the evaporator from icing up??
Old Nov 26, 2024 | 11:45 AM
Old Guy F-250's Avatar
Old Guy F-250
Well since we are guessing,
My guess is: Due to the size of the power bat and grd wires used possibly an electric heating element used to warm cab until the engine warms up used in real cold states...
MY GUESS..
Old Nov 26, 2024 | 12:33 PM
mterickson's Avatar
mterickson
MY GUESS..
I like that idea. My 2011 F350 PSD has the "rapid supplemental heat" option and it is exactly as you described, an electrical heating element next to heater core. I can start the truck cold in morning (below freezing), without block heater plugged in, and within a few blocks of driving I'll already have warm air coming from heater. I do know that option requires a bigger alternator when you add it and it sucks quite a bit of power from my understanding.
I'm not sure when they started offering that option from factory, but they had to get the idea for it from somewhere.
Old Nov 26, 2024 | 12:52 PM
tbear853's Avatar
tbear853
I was thinking some sort of either Ford or aftermarket add on that, would drop a heat element down in front of the blower fan, hole saw would make nice hole.
Old Nov 26, 2024 | 02:01 PM
5851a's Avatar
5851a
Never saw one, not Ford wiring. Wiring too small for any kind of heating. We may never know.
Old Nov 26, 2024 | 04:44 PM
Rubiranch's Avatar
Rubiranch
Follow the wires.
Cyrusjohn
Nov 15, 2017 03:04 PM
Etrizzino
Aug 2, 2016 01:27 PM
ryanelwood
Nov 24, 2012 10:11 PM
77 ford shortbed
Oct 19, 2008 09:14 PM
qdude79
Aug 29, 2005 07:27 PM
