need the right guy for this question electical
Old Oct 19, 2008 | 03:57 PM
77 ford shortbed's Avatar
77 ford shortbed
Red face need the right guy for this question electical
ok here goes I have a 1977 ford pickup truck. I will be installing factory ac right now the truck has just regular heat with just the heater box under the dash. My question is the wires that are going to the blower motor resistor now do they go to the newly installed factory ac blower motor resistors. an also the wires coming off the cold box there is a three prong plug do these get connected to the ac mode switch behind the ac controller there is one more wire red with a black stripe female connector does this one get connected to the single prong on the blower motor resistor. I didnt know if the wires coming off the cold box go to the blower motor resistors or go to the ac mode switch (phew)FINALLY GOT THAT OUT! any help would be great new to this forum. I LIKE IT. FORD TRUCKS RULE!
Old Oct 19, 2008 | 09:14 PM
okwaho1650's Avatar
okwaho1650
If you still have the donor truck follow the wires in it you will need to run some wires and the donor will help
