Crossover steering
I got a 1976 f250 F26 crewcab a year ago and have been slowing fixing some of the previous owners "fixes". Biggest issue I'm running into is the steering alignment/linkage. To my knowledge this truck was lifted and lowered many times over it's life and someone did a crossover steering swap, poorly and something looks off. I currently have a 78-79 4x4 steering box mounted to outside of frame rail but the drag link angle seems way off.
I've read alot of the Saginaw swap threads but nothing seems to match. Also has a factory dana 60
Thanks for any input
Any input
Starting on post #204 you can see my drag link. Mine is a 1975 F250 highboy, with a Dana 44 and power steering from a 1979 F250 4x4. I have not driven this yet with these modifications.
Do you have steering issues? It looks like you could get a high steer arm to bolt on the PS of your Dana 60 and have a straight drag link. Personally, the bent drag link shouldn't make any difference. I don't think heim joints are the best option though for street use.
Sweet looking truck by the way!
I'd lose the stabilizers too. no high boy/crew cab ever came with any and two is ridiculous it just overworks the system for nothing.
You do have a F150 box I believe. Mine is from a 79 F250 and is a 4 bolt box.
Your drag link swings in an arc so the end at the right front spindle moves left to right on those same bumps.
You are going to have bump steer bad. OK on a farm truck running farm roads.
Stock, that truck would have a drag link going front to rear to swing its arc and move the far end away from the steering box forward and back with the axle.
Side to side like on a F-150 is fine as they use coil springs and a trac bar that moves the axle left right on bumps to match the arc of the drag link as done in '78/'79 .... but it sucks on a '77 or older as they use funky "inverted Y" steering.
As mentioned by others the 78/79 F250 gearbox would have 4 bolts in it, so that's not what you have. Mine is mounted inside the frame and required some cutting/ welding (see great pics here as part of the Battle Born Brakes Kit: https://www.battlebornbrakes.com/pro...50-4wd-f26bstr)
I think this is the WFO crossover kit I used: https://www.wfoconcepts.com/i-305050...-draglink.html (old link in my thread no longer works)
This has a few pics of my stock steering setup for reference: https://www.ford-trucks.com/forums/1...-tip-help.html
When I ran my truck on the fully stock setup for a few years it drove straight and great. I was nervous to upgrade to a high pinion D60 and do crossover but it still drives great. Of course all of that cost more but it still drives wonderfully.
Previous owner definitely didn't do me any favors.
https://www.ruffstuffspecialties.com/R1796.html
Looks like the knuckles have been drilled for rod ends. They will not last long on the street and will have play in the bolts. A tapered tie rod is a better option. You may be able to reverse ream the knuckles and use a Chebby 1T TRE, on the top of the knuckles. The Chebby TRE are larger diameter than the Ford ones.
I would avoid a drop pitman arm puts a ton of leverage on the sector shaft and will wear out the lower bearing quickly. High steer arm is way better solution.
The dual steering stabilizers should not be needed at all. My first step would be to remove that and measure caster. If caster is under 2-3* it needs to be corrected.
A track bar (yes on leaf springs) will improve the steering response. 99-2004 super duty did this. The track bar needs to be fairly flat to work with leaves that don't want to move side to side.
This is my setup with high steer arm, reverse reamed knuckles with 1T TRE. No stabilizer. 80-96 steering box untouched. Zero bumpsteer. Took many changes and iterations to get there. It eats track bar heims, next are rebuildable joints.
Also thanks for the pics Smokey. That really helps along with nutters. Did you use the spring elimination kit as well? With the nylon caps?
Build thread has details of the revisions. It was difficult to package and not have it limit uptravel.
https://www.ford-trucks.com/forums/1...l#post20554342
