Portable Power Station
Old Nov 21, 2024 | 08:10 AM
Debbie152's Avatar
Debbie152
2nd Gear
NW North Dakota with frigid temps and high winds, truck sits daily for 12 hours on construction site. Last year the wind chill was -63 however I able to keep truck plugged in to power source. Has anyone used the portable power station to keep truck plugged in? Looking at the Anker SOLIX C1000 which is1800W (peak 2400W)
Old Nov 21, 2024 | 08:24 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You'd need to figure out how much power draw the truck will put on that battery pack to see if it would go 12 hours or not.
You are just powering the block heater?
Battery pack is rated at 1024wh, divided bt 12 hours means you have about 85 watts max per hour to spend.
Old Nov 21, 2024 | 08:53 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Also, looking on the manufacturer website, output rating is only down to -4 degrees, as it gets colder its output wattage will go down, so it won't power as much or as long below -4 degrees.
You'd need to keep it in a heated space during use to keep the power output up.
Old Nov 21, 2024 | 09:18 AM
Debbie152's Avatar
Debbie152
2nd Gear
Thank you. I thought about keeping it in the back of the truck in a wood frame with some insulation and enough circulation space. I think the scaffold builders are going to build a frame and we can run extension cords to the trucks safely.
Old Nov 21, 2024 | 04:01 PM
Garbageman 134's Avatar
Garbageman 134
A block heater will drain that pretty quick
Old Nov 21, 2024 | 04:59 PM
BC2019F250's Avatar
BC2019F250
Originally Posted by Debbie152
NW North Dakota with frigid temps and high winds, truck sits daily for 12 hours on construction site. Last year the wind chill was -63 however I able to keep truck plugged in to power source. (peak 2400W)
Just a point of clarification, wind chill only cools inanimate objects down to the ambient temperature faster but doesn't make them colder. If it is 0 degrees outside, your truck will not get colder than 0 degrees.
Wind chill really only affects people and animals.
Old Nov 22, 2024 | 01:44 PM
Tom S's Avatar
Tom S
Is a small generator an option if the other falls through? Keep it warm before hand so it starts good and then just let it chug along all day as needed. 1056 Watt hours on that power bank is going to go super fast with a 600w to 1000w block heater.
Old Nov 22, 2024 | 04:01 PM
2021F350's Avatar
2021F350
You could also put on a timer... 1Hr on 1Hr off and that should keep the engine warm enough... and the power station would/should last the 12Hrs... Anker SOLIX F3800 Solar Generator + 400W Solar Panel - Anker CA
Old Nov 22, 2024 | 05:01 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yeah, but the OP was looking at the 1000 not the 3800 you have linked.
Old Nov 22, 2024 | 05:05 PM
SARDiverDan's Avatar
SARDiverDan
The best performance you are going to get out of your block heater is three hours. Whether you plug it in for three ours or 12 hours, it is still only going to reach a certain temp. Anything beyond three hours is just wasting electricity. If you have a set timeframe on site, plug it in about three hours before quitting time.
Old Nov 22, 2024 | 05:19 PM
2021F350's Avatar
2021F350
I linked to the 3,800 because that is what I "think" will do the job...
Old Nov 22, 2024 | 05:22 PM
2021F350's Avatar
2021F350
Yes, that would also work... Unless he wants to leave early...
Vinford
2021+ F150
Jun 12, 2025 11:05 AM
Deanna43
5.0L Coyote
Nov 26, 2024 08:30 PM
R&S20
Jun 6, 2024 09:12 AM
Skidrowvet
2021+ F150
Jun 29, 2023 12:32 PM
Eddie 500
May 2, 2021 11:11 AM
