No Signal from TPMS
Old Nov 20, 2024 | 06:07 AM
Dan1954's Avatar
Dan1954
No Signal from TPMS
Has our 5th Wheel in to get work done on the black & grey water tanks. When returning from picking up the unit I discovered the TPMS signal was not being received according to the display. This is the first time I’ve had a problem in over 7 years of owning the trailer. In looking at the cable routing it appears the cable runs along the frame then under the coroplast sheeting. I have the 2017 TPMS version w/o tire temperature indication. 2017 F350. I was extremely bummed because I had to tow the trailer over 2 hours one way & it was in the shop over 2 months. It seems to me something must of happened while the work was being done. The wiring disconnected & not reconnected, the wiring pinched, cut etc. Can anyone recommend what I can check to try to diagnose this myself. Not sure where the cable goes after it runs under the coroplast or why the malfunction but it seems like more than coincidence that I experienced this problem the first time after black tank replacement. Thanks
Old Nov 20, 2024 | 06:20 AM
Dan1954's Avatar
Dan1954
Forgot to add, the trailer rear facing camera portion of the system is working fine.
Poppydawg
Jan 8, 2023 03:54 PM
DaleGolds
All Things Towing
Apr 13, 2022 07:03 AM
Midnite150
Nov 23, 2020 10:41 AM
MissIndependent
35
Jan 30, 2009 06:48 AM
Chance_Thomas
All Things Towing
Jun 7, 2006 11:08 PM
