Sponsored by: Real Truck
CP4
Old Nov 14, 2024 | 11:02 AM
NowhDixon's Avatar
NowhDixon
CP4
2015 f350 6.7. Was noticing my truck was low on power at high rpm. Plugged into it with a Snapon scanner and it was demanding 20k psi at high rpm, but only receiving 9-11k psi. The cp4 screen has only a TINY amount of shavings. CP4 is already out, same with fuel lines. Do I NEED to replace the lines and injectors? It didn’t go out like most people’s trucks do. No disco party glitter. It started and ran fine. I had towed with it a few weeks prior. Thanks for the help
Old Nov 16, 2024 | 04:11 PM
speakerfritz's Avatar
speakerfritz
The metering valve screen is 100 microns
the injector holes are 6 microns
if you don’t do a standard repair…you risk a problem return…
Gruntsquid
Aug 26, 2024 07:41 PM
andym
May 1, 2017 10:33 AM
Rishsd
Aug 15, 2013 08:44 AM
pjslawncare
Dec 10, 2006 09:08 PM
Cliford
Apr 28, 2004 11:31 PM
