6.9 fuel problem
Old Dec 10, 2006 | 07:09 PM
pjslawncare's Avatar
pjslawncare
6.9 fuel problem
Hi all, about 3 months ago my 6.9 started "bucking" at steady crusing at about 45 mph. It ran fine when under acceleration and deceleration butat a steady 45 it would buck wildly. Since then it has deteriated in performance to a point that it wont idle long before it dies. I changed fuel filter (twice) but no difference. Today I removed the complete air filter unit so I can get a better look and I noticed several fuel leaks from the high pressure lines entering the injectors. I suspect this is the problem or maybe the fuel supply pump may be going (or both). Is it possible to use a sealant on the high pressures or will I need to replace the lines totally? One guy on e-bay has the lines I need but the price is steep @ $45 ea. Does anyone know of more reasonable ones somewhere?
Thanks All and merry Christmas to you
Old Dec 10, 2006 | 07:12 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Best to change lines as the high pressure will blow off any surface fix. You might try a local salvage yard locally.
Old Dec 10, 2006 | 07:17 PM
CheaperJeeper's Avatar
CheaperJeeper
Are the leaks from holes in the lines, or are they cracked at the fittings? Have you tried tightening the fitting nuts?
Old Dec 10, 2006 | 07:24 PM
pjslawncare
Thanks for the quick replies guys. No the lines dont have any holes in them, the leaking is comming from the fittings at the aft side of the high pressure lines entering the injectors. seems like they are leaking thru the threads so I did try tightening them but still leaking and bubbling slightly.
Old Dec 10, 2006 | 08:32 PM
CheaperJeeper
You're sure it is the metal lines and not the plastic caps & rubber hoses for the fuel return lines?
Old Dec 10, 2006 | 09:08 PM
Dave Sponaugle's Avatar
Dave Sponaugle
http://www.mwfi.com/dieselPage/ford_73.htm
high pressure injection lines at reasonable prices
1cooltruck
1983 - 2012 Ranger & B-Series
Aug 21, 2013 09:01 PM
gummybear918714
19
May 29, 2011 02:56 PM
j tate
May 5, 2006 04:19 PM
Katmandu
Nov 11, 2005 10:43 PM
rangerboy21
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 29, 2004 05:35 PM
