Buzz test for the "hearing challanged"
I had some cold start/miss issues with the F350 and replaced the IDM with one from DTC. That cured the problem. Truck runs much better. Now I have the miss back. It's blowing smoke until it warms up and oil usage is quite a bit higher.
I downloaded Forscan to my laptop and started running some tests to find the issue. I ran the buzz test and had 5 injectors emit a much lower sound level than the other three. The injectors are original with approximately 110,000 miles on them. Low mileage, lots of idle time and low speed.
The truck was a "farm truck" and had apparently had a bunch of biodiesel run through it. When I dropped the fuel tank to fix an issue inside, there was about a half inch of, what looked like, grease in the bottom of the tank.
I removed all of that and flushed the fuel lines.
With the different sounds coming from the injectors and the way the truck is running, I'm thinking that I probably need new injectors. If I replace them, what would you recommend as far as brand and dealer? I've been thinking Alliant and Riffraff or CNC Fabrication.
I really enjoy this site and the people on it seem to know their stuff. Keep up the good work.
Gruntsquid out
https://www.rosewooddieselshop.com/
I got re-familiarized with Forscan and ran a few more tests.
DTIC - P0475 (exhaust pressure control valve malfunction) and P1298 (IDM failure). It's my understanding that the P1298 is normal with the high voltage/high current output version of this unit.
Perdels - idle to 1500 rpm
Cyl 1 - 0% constant
Cyl 2 - 0% to 8 %, erratic
Cyl 3 - 0% to 1.44%, erratic
Cyl 4 - 0%, constant
Cyl 5 - .3%, erratic
Cyl 6 - 0%, constant
Cyl 7 - 0%, constant
Cyl 8 - 8.5% to 9.7%, constant
ICP pressure - ~ 490 psi to 1167 psi @ 1500 rpm
IPR - 7.8% to 8.2% from idle to 1500 rpm. @ 3200 rpm it read 14.45%.
From 1500 rpm to 3200 rpm the cylinder readings were basically 0%.
Fuel pulse width - ~2.46 ms.
I did notice on the o'scope graph that all of the cylinder readings would go higher at ~the same time up to 1500 rpm. Possible air leak on fuel line?
Any suggestions as to other tests that need to be run?
Gruntsquid out
Cyl 1 - 0% constant
Gruntsquid out
An easy way to check for air in the fuel is to put a section of hose on the fuel bowl drain and run it into a jug. Open the valve and cycle the key for a second or 2. If you get any bubbles in the jug then you've got a leak in the suction side.
