High ICP
Old Apr 29, 2017 | 11:28 AM
andym's Avatar
andym
High ICP
I had a p1211 code when I first got Torque Pro hooked up. I figured it was just because I'd done a couple WOT runs and the HPOP just can't quite keep up with the injectors. I was told this might happen when I ordered the injectors from Gearhead. I also noticed that my ICP peaked at around 3600 during one of these runs. I don't have it logged, but I'm certain it was up that high.
The code hasn't returned, but I haven't been running it too hard either. I don't quite know what to make of the ICPs actually being that high. From looking at a bunch of Rich's graphs his doesn't really get past 2800 or 2900. Is this an incorrect reading? Do I need to worry about anything?
Old Apr 30, 2017 | 05:22 AM
Tugly's Avatar
Tugly
P1211 with a 3600 PSI max PSI marker - classic Stinky Spike. [LINK]
Old Apr 30, 2017 | 09:19 PM
jhl3's Avatar
jhl3
The ICP on this truck will sometimes peak at around 3500 PSI on a WOT run. I have not logged it to see what IPRDC% is being commanded when it peaks this high but it is definitely at about 2400-2600 rpms, FIPW is below 2.2ms and the peak happens when I am pulling a heavy load up a 7% grade and when I am getting into the throttle way before I let off the throttle. The HPOP will maintain 3000+ all the way up the grade.
I think this rules out a Stinky spike on my truck. How does that compare to your experience?
Old May 1, 2017 | 07:28 AM
Tugly's Avatar
Tugly
Originally Posted by jhl3
The ICP on this truck will sometimes peak at around 3500 PSI on a WOT run. I have not logged it to see what IPRDC% is being commanded when it peaks this high but it is definitely at about 2400-2600 rpms, FIPW is below 2.2ms and the peak happens when I am pulling a heavy load up a 7% grade and when I am getting into the throttle way before I let off the throttle. The HPOP will maintain 3000+ all the way up the grade....
I would need to see a full log of MPH, RPM, FIPW, ICP, and IPR to see what's going on in there.
Old May 1, 2017 | 08:42 AM
andym's Avatar
andym
As soon as I get driveshaft back together, I'm going to try to log data.
I've read that thread before. Still trying to wrap my head around it. Most of it makes sense to me but I don't feel like I get all the finer points.
Old May 1, 2017 | 09:30 AM
Tugly's Avatar
Tugly
Nutshelling it - IPR is not unlike putting your thumb over a garden hose. Take a hose and adjust the water flow to where the water comes up about 1/2 to one inch above the nozzle - that is a finite amount of flow available. Move your thumb just enough to let a little water out and pressure builds (this is ICP) - shooting the water a greater distance. Letting your thumb off completely allows the pressure to escape, and the water just gurgles out. ICP powers the injectors... which is all about atomization - it takes high pressure to do it right.
FIPW is akin to putting a Y in the garden hose and bleeding some or all of your pressure. If the FIPW isn't too long, the thumb on the hose can adjust a bit to keep the pressure up. There is a delicate balance between increasing the flow out that Y and decreasing the pressure beyond what the IPR can correct - a good performance tune strikes that balance. A long FIPW just drains your ICP out the Y... and you get soot, high EGTs, and diminished performance.
Old May 1, 2017 | 10:33 AM
andym's Avatar
andym
It sounds like I either need a bigger HPOP (should have listened to gearhead there) or a tune that doesn't hold the FIPW open quite as long.
BBslider001
34
Jan 9, 2019 11:07 PM
ernesteugene
Mar 30, 2009 06:02 PM
muddog899
Sep 22, 2006 06:24 PM
firemanbird
Aug 25, 2006 01:02 AM
BuickTurbo
Oct 27, 2005 05:11 PM
