Intake manifold
Old Nov 12, 2024 | 06:22 AM
Akumothesaiyan's Avatar
Akumothesaiyan
Trailering
Intake manifold
I have a 1982 f350 with a 351windsor I've been rebuilding and I was wondering what intake manifold I should use. I have a brand new Edelbrock 1905 and an Edelbrock intake but the intake seems like it's not tall enough? Seems like it's sucking air from somewhere and I realized I can see the very tops of the ports in the heads. Did the truck 351w have taller heads than the cars or what?
I took off the original intake it was a two barrel originally
Old Nov 12, 2024 | 06:26 AM
Franklin2's Avatar
Franklin2
Are you sure you have the correct intake? Sounds like you have a 302 intake. The 302 and 351w have a lot of interchangeable parts, they are basically the same engine, except the 351w has a taller block. So that makes the "V" of the engine wider.
Old Nov 12, 2024 | 07:29 AM
Akumothesaiyan
Trailering
It says performer 351w on the top of it
Old Nov 12, 2024 | 08:02 AM
Franklin2's Avatar
Franklin2
Are you sure you have a 351w? How many bolts hold each valve cover on? 6 or 8?
Old Nov 12, 2024 | 08:16 AM
Akumothesaiyan
Trailering
6 I've finished putting it together just trying to crank it and adjust things
Old Nov 13, 2024 | 07:37 AM
FuzzFace2's Avatar
FuzzFace2
Got a picture of the issue and the intake as we may see something you dont see.
When fitting intakes to motors I drop them on with out the gaskets so I can see if the angle of the intake and heads are the same and when the gap is between intake and block at the front & rear so I know how thick the bead of gasket maker has to be, I dont use the rubber or cork end gaskets.
This will tell me if the intake will work or not.
Dave ----
bleeds blue
Aug 12, 2023 05:20 PM
chuck3908
May 15, 2021 02:55 PM
bigfoot7180
26
Jun 20, 2011 10:19 PM
mdh627
Jul 20, 2003 10:34 AM
