Throttle Position Sensor Low Voltage
Old Nov 14, 2024 | 02:47 PM
chearn1's Avatar
chearn1
Trailering
Good question! I will have to check and see. Thanks!
Old Nov 16, 2024 | 03:16 PM
chearn1's Avatar
chearn1
Trailering
The TPS is snug with no play at all when I locate it so the bushing must be in there.
Old Nov 16, 2024 | 04:04 PM
Junktownbill99's Avatar
Junktownbill99
1. Why are you on a different account?
2. Take it off to check if the bushing is there, if the screws are tight, it won't move when you grab it.
Old Nov 16, 2024 | 09:55 PM
chearn1's Avatar
chearn1
Trailering
Long story about different account. The bushing is in there I saw it. The TPS has no sideways movement when installed in the throttle body without the screws being tight. Thanks!
Old Nov 17, 2024 | 12:45 PM
chearn1's Avatar
chearn1
Trailering
I checked the voltages on my TPS yesterday. I think I got a bad after market TPS. When I checked the voltage it was 5.0 volts with the throttle in the closed position and in the wide open position. I'll get a Motor Craft sensor and try that. Thanks for your help.
Old Nov 17, 2024 | 01:02 PM
Junktownbill99
Did you test the orange wire? That's reference voltage, always 5v. Green to black tests the variability of the sensor.
Old Nov 18, 2024 | 04:05 PM
chearn1's Avatar
chearn1
Trailering
I don't have an orange wire. My top wire is black with a white stripe, this is the one I get the 5 volts on. My middle wire is solid white and my bottom wire is white with a red stripe. I placed my hot probe in the bottom wire (white with red stripe) and my ground probe in the white wire. My meter was showing 0.03, I advanced the accelerator to full throttle and the meter showed 0.05. I removed the probes and then reinserted them and I could never get another reading. I tried for 30 minutes until I started getting frustrated and I quit for the day. Going to get a motor craftd TPS and see how it goes. I'll get back as soon as I locate one and get it in. Thanks.
Old Nov 19, 2024 | 08:17 AM
manicmechanic007's Avatar
manicmechanic007
They changed wire colors on that circuit at least twice
His 1990 4.9 has this schematic
Back probe them all until you get a variable reading as you move the throttle
Hard to see those wire colors after years and years
These are out of a 1990 Truck EVTM
Old Nov 19, 2024 | 05:19 PM
chearn1's Avatar
chearn1
Trailering
That's my truck. Thanks for the info!l I have ordered a new MotorCraft Sensor but with backorder it may be a couple of weeks before I get it. Tried to upload photo but new at WIN 11 PRO. It saves photos the way it wants to instead of the way I want them.
BigBlue92
Mar 7, 2025 08:39 AM
Tommyy293
Nov 16, 2024 03:17 PM
AMSContr
Jul 5, 2008 09:42 PM
Iron Horseman
Mar 23, 2006 04:28 PM
John7894
Jan 14, 2003 04:41 PM
