92 Accelerate slowly
Old Nov 11, 2024 | 10:48 AM
f1butcher's Avatar
f1butcher
I have 1992 E-150 and tell me is there a vacuum hose or line that connects to the accelerate pedal cause when I push to start moving the van its seem stiff like I hear vacuum holding it back, you cannot just push the petal to the floor quickly or easy. So I push it in slowly and it finally start to move, it just seems it should move easier than this. f1butcher
Old Nov 12, 2024 | 05:53 AM
manicmechanic007's Avatar
manicmechanic007
Your automatic transmission or clutch (if it's a manual trans) is slipping it sounds like
There is no vacuum line going to the accelerator pedal
Any vacuum noise you are hearing must be just from the engine
You could do a few static intake manifold smoke tests and see if your intake or anything else is leaking vacuum
Old Nov 12, 2024 | 11:55 AM
f1butcher's Avatar
f1butcher
Thanks, the transmission needs work its an AOD automatic . How or what do I need to to do the smoke test ?
RacerX10
Jan 12, 2017 10:01 AM
BIGRED 7.3L
Mar 2, 2010 03:00 PM
Rulebreaker
Aerostar
Feb 28, 2008 09:17 PM
tarditi
Jul 22, 2007 09:15 PM
77F-150
Aerostar
May 3, 2005 11:28 PM
