2008 E-250 won't crank
Old Nov 2, 2024 | 10:07 PM
InsaneGeek's Avatar
InsaneGeek
1st Gear
Have a base model 2008 e-250 I purchased at auction with no PATS that won't crank with antitheft light flashing. It died twice while driving and took a number of minutes of flashing antitheft but eventually started, it now wont crank at all after trying for a few days. Using Forscan it says it cannot talk to the PCM (see attached) and a number of other modules can't talk to it. The odometer after a few minutes turns to all dashes, I picked up a junkyard PCM but no luck with same issue. The key assembly doesn't have a PATS ring only around it, only the small key inserted sensor, so I don't believe PATS antitheft engaged. Looking for things to maybe try next
Instrument gauge blink codes are:
Antitheft light rapidly blinks for 1 min then slower blinks for , 1x 21x 14x 7x 6x 7x 6x 7x
Airbag light, on for 6x seconds, then blinks 1x 4x 5x 1x 4x then remains on
File Type: txt
Old Nov 13, 2024 | 06:32 AM
pancake52's Avatar
pancake52
good connections?
ok no anti theft on my 98 e150 4.6l, but bend and ck your battery connections. my positive was corroded under the insulating plastic. no juice got thru. ck the neg ground thru out. does your dash light up properly and stay on when you turn the key to crank over.
Old Nov 13, 2024 | 11:01 AM
Don Ridley's Avatar
Don Ridley
The Forscan data appears to show there is a problem with the communication network(s). I am not familiar with the network architecture on your 2009. I don't know your electronics/electrical knowledge but I would watch some YouTube videos on how to troubleshoot CAN networks. Then pull the wiring diagram on your van. I think the network on these older vans is pretty simple compared to a new vehicle.
You may have a bad instrument cluster that is pulling the network down. I think Forscan can communicate with the PCM but it can't read a particular DTC.
This website has wiring diagrams. I have navigated to your model year van.
https://charm.li/Ford%20Truck/2008/E...d%20Diagnosis/
roboford
Apr 29, 2023 10:29 PM
GriffinB
Mar 14, 2023 05:07 PM
Cam (didit)
6.4L Power Stroke Diesel
Nov 11, 2021 05:01 AM
M.Lusk
1997 - 2003 F150
Jan 31, 2021 08:57 PM
springwater
General Automotive Discussion
Mar 20, 2016 06:19 AM
