CAC Boot Sanity Check
Old Nov 1, 2024 | 02:10 PM
Hot pocket's Avatar
Hot pocket
Hey Guys,
Yesterday I was changing out my intercooler CAC boots at the intercooler and at the spider with new very slick looking blue Riff Raff boots.
On the drivers side spider connection, the lifting eye on the block was interfering with the more robust boot. I ended up taking off the eye just to get the boot on.
It appeared that if i left it as is it would rub a hole in the boot over time.
Has anyone else had this experience? (I put the bolts back into the block for safe keeping)
Thanks in advance
HP
Old Nov 1, 2024 | 03:33 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Here is the squeaky clean engine bay of the impeccably maintained masterpiece modified by @Blueforester , with RiffRaff boots:
As you can see, the driver's side engine lift eye is still in place, and if there were even a scintilla of rubbing concern, BlueForester wouldn't run it.
On my truck, the Banks boots might be even thicker than RR boots, and I never had the need to remove the engine lift eye either.
No rubbing.
Old Nov 1, 2024 | 03:56 PM
Blueforester's Avatar
Blueforester
Just a haunch. Curious if the engine has ever been removed/replaced? The lifting eyes will tend to bend slightly with the weight of the engine. And depending on if using a chain or short engine leveler to remove or install. It may be that yours are just bent?
Blue
Old Nov 1, 2024 | 03:58 PM
Hot pocket's Avatar
Hot pocket
Well Shoot, how did I mess this one up? haha
Old Nov 1, 2024 | 04:07 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Early 99 or Late 99?
Old Nov 1, 2024 | 04:11 PM
Hot pocket's Avatar
Hot pocket
Late 99 model. Ill try to post pics when i get home.
Old Nov 1, 2024 | 05:08 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Isn't that the side where the tube is capable of going in backward or reverse from what it should be?
Old Nov 3, 2024 | 01:01 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Good guess, driver side easy to swap end to end. Passenger side no way.
Just did new boots 2 days ago.
Old Nov 3, 2024 | 08:21 AM
bwguardian's Avatar
bwguardian
You can tweak the position of the pipes too. The driver side...like you're talking about...had to be rotated a little bit to get them to align better when I replaced mine first part of this year.
Old Nov 3, 2024 | 02:16 PM
RA101725's Avatar
RA101725
Banned
Hate that pipe. Passenger (cold) side fits fine though.
UGA33
Apr 5, 2018 06:17 AM
winginit
6.2L V8
Jan 20, 2014 11:54 PM
mswift
Nov 19, 2006 07:49 AM
Randyb12
Sep 8, 2003 10:50 AM
stemen_a
Mar 10, 2003 12:49 AM
