Ground Problem
Old Oct 28, 2024 | 09:06 PM
Sprocket118's Avatar
Sprocket118
Ground Problem
I walked into the garage this evening and noticed my brake lights were on. They must have been on for a while because the wire connectors I pulled of the pressure switch were hot. I have previously grounded both tail/brake lights running a wire from the lights to the frame. ( I had one light that was brighter than the other.) I am now wondering where else to look? Also when I removed the tail lights from their mount the lights went out. Any suggestions are welcome.
Mike
Old Oct 28, 2024 | 10:32 PM
Bob Ingram's Avatar
Bob Ingram
That doesn't sound like a ground problem. It sounds like you have voltage going to the lights, maybe through the switch, but maybe through another source.
Old Oct 28, 2024 | 11:00 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Could the pressure switch be failing? Or the brake pedal adjusted a little too tight, not allowing all of the pressure to be released?
Old Oct 29, 2024 | 03:40 AM
ingo's Avatar
ingo
I don´t like the pressure switches they have too many failures. I put a motorcycle brakelight switch in all my old vehicles.
Old Oct 29, 2024 | 05:13 AM
52 Merc's Avatar
52 Merc
Mike
The lamps are grounded through the mount, so when you removed the lamp from the mount you ungrounded it and broke continuity, which is why the light went out. If you had power going through the switch at rest, as noted above, you either have a bad switch or have a mis-adjustment in your linkage, causing pressure at the switch which is closing the switch, sending power to the lamps.
Old Oct 29, 2024 | 07:07 AM
lshort's Avatar
lshort
do the lights go out when you remove a wire from the brake pressure switch?
also try fiddling with the turn signal switch and hazard light switch.
Old Oct 29, 2024 | 07:25 AM
hooler1's Avatar
hooler1
Good move! I did that to mine too for the exact same reason. It fixed the brightness issues between the the two sides.
About the brake lights being on. I agree with the others. Its probably a bad brake light pressure switch. You could either replace it or use one if those universal mechanical ones with the little adjustable arm that rides on the outside of the brake pedal arm. If you don't want to drill some small mounting holes to the bottom of the cab to hold it over the brake pedal arm you will need to come up with some kind of bracket to bolt the bracket and switch to the frame. I did the latter on mine and it works very well.
Sorry I don't have pics for you.
Old Oct 29, 2024 | 08:00 AM
jniolon's Avatar
jniolon
old and in the way
the good news is that your brake wiring is working fine !!! I'd get rid of the hydraulic switch and go with an electric switch at the pedal. I tried three hydraulics (all leaked) before I switched over
mechanical brake light switch
\j
Old Oct 29, 2024 | 08:35 AM
Sprocket118
Thanks guys, I was thinking it was the switch but it is a relatively new switch. I can start there anyway and replace the switch then look more into an electrical/mechanical switch.
Old Oct 29, 2024 | 09:00 AM
lshort's Avatar
lshort
\j
The problem is with chinesium quality parts, I bet if you could find a NOS switch it would be fine.
Old Oct 29, 2024 | 09:19 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Personally, I have never had an issue with the stock style brake switches in my fleet. I think most reported issues with the pressure switches are improper installation with too much torque which compromises the unit. Simply use a deep socket and don't go all HULK SMASH on it.
Old Oct 29, 2024 | 10:03 AM
Sprocket118
Thanks for the tip bmoran4
Old Oct 29, 2024 | 10:07 AM
abe's Avatar
abe
My brake light switch failed at Truckstock as guys following can testify to. I ordered a new one from Midwest Early Ford for only $7. It works fine for now. Whenever I back into the garage I check for brake lights.
bmoran has a good suggestion about not cranking the switch too tight. That makes sense.
Old Oct 29, 2024 | 10:16 AM
lshort's Avatar
lshort
I realized that the one that I had fail was not working when the cruise control would not disengage further inspection showed that it was leaking a small amount coming out of the switch end, I had similar multiple problems with a F250 cruise control switch from Orileys, a motorcraft unit solved the problem.
I assume that of all the switches available there is a range of quality but how to figure out a good one
stx2006
2004 - 2008 F150
Mar 23, 2008 09:34 PM
TheMech
Jan 30, 2008 10:15 AM
tcbofade
Sep 22, 2006 02:57 AM
62Cole
Feb 3, 2006 03:21 PM
stepside64
Electrical Systems/Wiring
Mar 15, 2004 08:58 PM
