Brake/Tail light issue
Old Sep 10, 2006 | 10:56 PM
tcbofade's Avatar
tcbofade
Got my first ticket in over ten years tonite. Apparently, I was driving without tail lights or brake lights. After receiving a $75 ticket, I of course checked to see if the lights were operating. Brakes lights work fine if tail lights are not turned on.
Again. With the head/tail lights off, the brake lights work. With the head/tail lights on, the tail lights don't work and neither do the brake lights.
Where do I start?
(Besides the fact that I'll stick to daytime driving for a while...)
Old Sep 10, 2006 | 11:48 PM
Torque1st's Avatar
Torque1st
Posting Legend
Bad grounds, check out the tech article on lights here:
https://www.ford-trucks.com/article/...rd_Pickup.html
There is also some info in the Read First: FAQ thread in this forum.
Old Sep 11, 2006 | 04:41 PM
tcbofade's Avatar
tcbofade
Thank you, Eric.
So I pulled the fixtures out of the bed, and visually inspected some rotten looking grounds. The wire looks OK, but the spot on the body where they ground is rusting away...jiggled the wires, and presto! Seems to work again. I'm thinking I'll run some new ground wire maybe even to the frame on the weekend.
Dear Lord, could they just work for a few days?????
Old Sep 11, 2006 | 04:59 PM
Mil1ion's Avatar
Mil1ion
Put some of that "from rust back to metal" stuff on that spot.
What's it called POR or something like that ?
Old Sep 12, 2006 | 08:09 AM
tcbofade's Avatar
tcbofade
Grumble. Grumble. Update.
OK. Now the tail lights work.
Without the tail lights on, both brake lights work.
With the tail lights on, stepping on the brake pedal causes the left rear light to brighten as it should, but also causes the right rear light to go out.
I need a longer neck for this job...
Old Sep 12, 2006 | 03:03 PM
tango54464's Avatar
tango54464
i had a similar problem on my 78 f100 . check the bulb sockets them self. they might have some corrosion in them. i ended up replacing them and the they work as advertized. you can get new sockets at advanced or autozone for about 10.00 or 12.00 bucks each.
Old Sep 13, 2006 | 01:29 AM
Mil1ion's Avatar
Mil1ion
It's all smoke and ........Mirrors
Old Sep 14, 2006 | 04:35 AM
LisaDi9's Avatar
LisaDi9
Mil1on Can you tell me the name of the book that flow chart came from? I am trying to track down multiple wiring issues in a recently purchased 1976 F100. Thanks much.
Old Sep 14, 2006 | 12:36 PM
Mil1ion's Avatar
Mil1ion
Just read post #22 on this thread then call them.
https://www.ford-trucks.com/forums/4...100-302-a.html
This is what you'll get.
http://www.detroitironis.com/default.asp
Old Sep 15, 2006 | 02:00 AM
LisaDi9's Avatar
LisaDi9
Thanks alot.
Old Sep 22, 2006 | 02:57 AM
efftwofifty's Avatar
efftwofifty
i've had to replace the sockets in every ford truck ive had...the groud rusts out easily. The other problem ive had with the lighting is the ground on the light swtch going, and replacing that is the only way.
Byrd.Dog
Aug 30, 2010 09:35 PM
truckhound
Electrical Systems/Wiring
Dec 30, 2007 01:12 PM
soulwinnerrj
Oct 31, 2007 07:55 PM
tcbofade
Missouri Chapter
15
Sep 21, 2006 03:53 AM
dflint
Jan 26, 2000 09:18 PM
