Hi, I am new to the F250 Super Duty group. I have just upgraded my wheels and tires to 35's. Do I need to change anything in the computer or tell it anything so that it knows? I have a 2017 with a 6.2 4 door with an 8ft bed. Thanks
With 35's, the speed may be closer to accurate than when it rolled off the dealer lot. Find a good app that tracks your speed and compare the two. You might be surprised.
I have 35x12.50R18 on my '19 and GPS shows that I'm 3 MPH off at interstate speed, 2 MPH off on slower highways. Not a big deal. As the tread wears down it'll get closer to reality.
Try the tire size calculator in the ForScan sticky. It will get you close.
Been running 35/12.5/20's on my 2017 since 200 miles on the clock. MPH has always been within about 1-2 mph, accurate enough for me. I run about 60 pounds of pressure so I used Forscan to eliminate the low pressure TPMS notification.
