How long do I have?
Old Oct 28, 2024 | 07:54 PM
B00ZEH0UND's Avatar
B00ZEH0UND
4wd Low
How long do I have?
My 2018 F350 6.7L Turbo Diesel popped code P24B0, Particulate Matter Sensor Low Voltage. I dont have the scratch to replace it at the moment, but I still need to use the truck. How long can I run on it before it becomes an even more expensive issue?
Old Oct 29, 2024 | 05:43 AM
stryder's Avatar
stryder
Take 5 minutes and crawl under the truck to check the sensor wiring and module for damage. Particulate sensor is the last one in the exhaust system, just past the rear axle. Replacement was under $200 for sensor and module. As far as how long...being the last sensor and a voltage issue, I'd say send it until you get it fixed.
Old Oct 29, 2024 | 09:03 AM
cpobst's Avatar
cpobst
If I remember right there is a TSB for this. At least there was for my 2017. I ended up replacing it myself because it was cheaper than taking it to the dealer.
Edit: https://static.nhtsa.gov/odi/tsbs/2018/MC-10153928-9999.pdf
It doesn't show your code but I bet just replacing the sensor will fix it. I feel like I paid under $100 for mine.
Old Oct 29, 2024 | 09:45 AM
B00ZEH0UND's Avatar
B00ZEH0UND
4wd Low
Thank you!
murraycookies
Jul 7, 2024 06:23 PM
MelissaBurney
6.7L Power Stroke Diesel
Jun 1, 2017 12:09 PM
PetersPatio
Feb 14, 2014 02:49 PM
Corkm
May 18, 2011 08:51 PM
