The Dreaded SES light!!
Old Oct 17, 2024 | 06:41 PM
ZachinCO's Avatar
ZachinCO
My truck sits more than it gets driven these days, but went to town the other day and got an intermittent SES light, no accelerator pedal for a few seconds then it would go off, back to normal. Sat for a week or so and went to take it to town last night and this time it stayed on.
Today I move it over to the shop, run FORScan Lite:
===OBDII DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC===
===PCM DTC P0475===
Code: P0475 - Exhaust pressure control valve malfunction
Module: Powertrain Control Module
Diagnostic Trouble Code details
This DTC may be caused by :
Open circuit.
Short circuit
Possible causes are:
Harness wiring
Exhaust back Pressure Regulator
PCM
Inspect connectors for signs of damage, water ingress, corrosion, etc.
===END PCM DTC===
===PCM DTC P0221===
Code: P0221 - Throttle Position Switch B Circuit Range/Performance
Open circuit.
Harness wiring
Idle Validation Switch
PCM
===END PCM DTC===
===PCM DTC P1247===
Code: P1247 - Turbo Boost Pressure Low
Low boost pressure
Air leaks at the intake manifold or crossover tubes
Map Sensor
PCM
Follow the routines in the service manual to resolve the DTC listed.
===END PCM DTC===
===PCM DTC P0541===
Code: P0541 - Manifold Intake Air Heater Circuit Low
Open circuit.
Short to Ground
Harness wiring
MIAH Relay
PCM
===END PCM DTC===
===PAM DTC C1706===
Code: C1706 - Rear Inner Left Sensor Circuit Failure
Module: Parking Aid Module
===END PAM DTC===
===PAM DTC C1704===
Code: C1704 - Rear Outer Right Sensor Fault
===END PAM DTC===
===PAM DTC C1703===
Code: C1703 - Rear Outer Right Sensor Circuit Failure
===END PAM DTC===
===PAM DTC C1701===
Code: C1701 - Rear Outer Left Sensor Fault
---------------- Possible Causes --------------
Internal sensor failure.
Check if sensor face is free from obstructions.
===END PAM DTC===
===PAM DTC C1700===
Code: C1700 - Rear Outer Left Sensor Circuit Failure
===END PAM DTC===
===OTC DTC B1203===
Code: B1203 - Fuel sender circuit short to battery
Module: Overhead Trip Computer
===END OTC DTC===
===ECS DTC ===
Module: Electronic Crash Sensor
===END ECS DTC===
===GEM DTC ===
Module: Generic Electronic Module
===END GEM DTC===
===ABS DTC C1185===
Code: C1185 - ABS Power Relay Output Circuit Failure
Module: Antilock braking system
===END ABS DTC===
===ABS DTC C1198===
Code: C1198 - Left Front Inlet Valve Coil Circuit Failure
===END ABS DTC===
===ABS DTC C1214===
Code: C1214 - Right Front Inlet Valve Coil Circuit Failure
===END ABS DTC===
I've done a visual, can't see anything amiss. Harnesses appear to be tight. No visual indicators that set me off.
If I sit there, the SES will go off, I can get 1 Rev, then back on. Rinse & repeat.
I'm planning on doing the oil cooler o-rings this weekend. Oil level is good currently.
Any direction to start or other FORScan pids to run?
Old Oct 17, 2024 | 07:24 PM
Pikachu's Avatar
Pikachu
Depending on the type of accelerator pedal sensor assembly you have, you may have a separate IVS (idle validation switch) and position sensor. If you do have that setup, this addresses the IVS. If you're APP sensor and IVS switch are integrated, I'm not sure if you can clean it or not; I've never tried on that style.
You should be able to see the IVS status and APP percentage in ForScan. That's probably the first code I'd chase down in order to be able to drive it to diagnose the others.
Old Oct 18, 2024 | 09:06 AM
ZachinCO's Avatar
ZachinCO
I saw some of those videos last night. I'll be diving into that this weekend.
Old Oct 18, 2024 | 09:18 AM
udsuth78's Avatar
udsuth78
Are these codes recuring? Meaning you've cleared them and these are what comes back? If you haven't cleared them yet then that's where I'd start. Some of those codes could be as old as your batteries and not actually an issue.
Old Oct 20, 2024 | 12:40 PM
ZachinCO's Avatar
ZachinCO
Codes cleared.
I pulled the pedal assy. off and cleaned it up. Seems to have been the issue. Reinstalled and only codes I have now are:
P0475
P0541
Fairly certain those are constant and haven't been affecting driveability.
I will probably pick up a backup pedal assy and have it onboard just in case.
Redneckmorton
Feb 27, 2026 12:58 AM
Listor
Dec 16, 2022 07:35 AM
Listor
Jul 10, 2021 02:20 AM
watersurgeon
May 4, 2021 06:52 PM
wyoclint
Dec 15, 2016 05:02 PM
