ABS Light on, Speedometer, and Odometer not working. Flashing OD light. ***Resolved***
Howdy yall, Its been a while since I've been on the boards here. Sold my 96 F350 about a year and a half ago and just picked up a e99 a about 6 months ago. Needing some help and figured I'd stop in the best place I know!!!
early 99 F350 CCLWB DWW 4x4 Lariat
As the title say the ABS Light is on, the Speedometer, and Odometer are not working, and the OD light is flashing.
When I bought the truck, I replaced all the front end components. Including upgrading to 2000 style hubs and brakes.
I have read thread after thread on the symptoms and everything comes back to changing the VSS on the rear diff. I have replaced it twice, the first time with an after market, the second time with an OEM.
When I first started noticing an issue, the speedometer dropped out and came right back in. Later on it did the same thing but right after the ABS light came on. Got home, turned the truck off, back on and everything was back to normal. Headed back out a while later and the ABS light came on and stayed on. Every so often the speedometer would drop out. Then later the OD light started flashing. Found a place to pull over turned the truck off, back on and all back to normal. A few miles down the road and it started back over.
After some research, I replaced the VSS, and the problem seemed to go away. Headed out for a weekend trip, and the problem started all back over from square one. Remind you the truck runs fine with no issues, that I can tell anyways. On the way home the ABS light stays on, the OD light keeps flashing, Speedometer was still working. A couple days later the speedometer stopped working. (I just noticed this morning the odometer not working.)
Changed the VSS to the OEM and no change at all.
I'm getting ready to head out Sunday morning on a 1000 mile round trip and want to make sure the truck isn't going to be harmed.
I've seen some people talk about ohming the connector out, but never seen instructions on what to do.
I did have an issue with the windshield leaking. Replaced it and as far as I can tell its no longer leaking. The GEM, and fuse box has been replaced as well, due to it being all corroded.
I changed the diff fluid in it back when I was working on the truck, and everything looked good on the inside.
Anything else yall need to know, just let me know.
I do have an obdlink module. However I haven't bought the full version of forscan. Is it worth it? I know the obdlink app doesn't like my truck. Here is the list from forscan that I have. I never did unhook the batteries after changing the vss and leaving them undone. But I've tried clearing the codes and theyou never seem to go away. I know my truck has a lot of issues, but I haven't gotten around to trying to fix them all. That's coming up before long.
===OBDII DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII===
===PCM DTC P0238===
Code: P0238 - Turbo/Super Charger Boost Sensor A Circuit High
Module: Powertrain Control Module
Diagnostic Trouble Code details
Follow the routines in the service manual to resolve the DTC listed.
===END PCM===
===PCM DTC P1249===
Code: P1249 - Wastegate Control Valve Performance
===END PCM===
===PCM DTC P0500===
Code: P0500 - VSS sensor circuit fault.
Open VSS circuit.
Shorted VSS circuit.
This DTC may be caused by :
Suspect VSS.
Worn or Damaged VSS drive gear on transmission output shaft.
Suspect PCM.
Faulty or damaged instrument cluster module.
===END PCM===
===PCM DTC P0603===
Code: P0603 - Power interruption on KAPWR circuit.
Open KAPWRcircuit.
Loose/poor battery connections at the battery and engine block.
If a recent PCM disconnect or battery disconnect is suspected no action is required unless the code continues to appear after being cleared.
Reprogramming can cause this code. If reprogramming was done clear codes and release vehicle.
Improper connection
===END PCM===
===PCM DTC P1211===
Code: P1211 - Injector Control Pressure Higher/Lower Than Desired (engine running)
===END PCM===
===OTC DTC P0500===
Module: Overhead Trip Computer
Open VSS circuit.
Suspect VSS.
Suspect PCM.
===END OTC===
===OTC DTC U2015===
Code: U2015 - Overhead Trip Computer Signal Link Circuit Failure
Operator Action
Run self test.
All CMDTCs
Fix all relevant DTCs then clear codes and retest.
Note:
DTCs that start with 'U' are faults which occur during module-to-module communication.
Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle.
===END OTC===
===OTC DTC B1203===
Code: B1203 - Fuel sender circuit short to battery
===END OTC===
===ECS DTC B1318===
Code: B1318 - Battery voltage Low
Module: Electronic Crash Sensor
Battery Voltage Too Low
--- Possible Causes --------
- Battery Voltage below 9.6volts
-Suspect Battery state of charge Charging system
===END ECS===
===GEM DTC B1352===
Code: B1352 - Ignition key in circuit fault
Module: Generic Electronic Module
This DTC can be generated by:
-Open Key-In Ignition Switch circuit
- Battery short Key-In Ignition Switch circuit
- Battery short Ignition Switch RUN/ACCY circuit
- Suspect Ignition Switch
- Suspect Lighting Control Module.
===END GEM===
===GEM DTC B1310===
Code: B1310 - Power door unlock circuit failure
-Open Driver Central Lock Switch
-Suspect Driver Central Lock Switch
-Suspect Generic Electronic Module
===END GEM===
===GEM DTC B1300===
Code: B1300 - Power door lock relay coil circuit failure
Power door lock circuit failure
Open circuit, short to ground, or to battery
-Suspect
Circuit wiring Defective module
===END GEM===
===GEM DTC B1217===
Code: B1217 - Horn Relay Coil Circuit Failure
Horn relay coil circuit short to battery
===END GEM===
===GEM DTC B1323===
Code: B1323 - Door Ajar Warning Lamp circuit failure
This code can be generated by:
-Open/Short circuit between Door Ajar Warning Lamp and Generic Electronic Module
- Open/Short circuit between Door Ajar Warning Lamp and power circuit
- Suspect Door Ajar Warning Lamp
- Suspect Generic Electronic Module.
===END GEM===
After downloading the full version, I was able to get the codes to disappear. So we will see if any of them come back.
===OBDII DTC ===
===END OBDII===
===PCM DTC P0238===
===END PCM===
===PCM DTC P1249===
===END PCM===
===PCM DTC P0500===
Open VSS circuit.
Suspect VSS.
Suspect PCM.
===END PCM===
===PCM DTC P0603===
Open KAPWRcircuit.
Improper connection
===END PCM===
===PCM DTC P1211===
===END PCM===
===OTC DTC P0500===
Open VSS circuit.
Suspect VSS.
Suspect PCM.
===END OTC===
===OTC DTC U2015===
Operator Action
Run self test.
All CMDTCs
Note:
===END OTC===
===OTC DTC B1203===
===END OTC===
===ECS DTC B1318===
===END ECS===
===GEM DTC B1352===
===END GEM===
===GEM DTC B1310===
===END GEM===
===GEM DTC B1300===
-Suspect
===END GEM===
===GEM DTC B1217===
===END GEM===
===GEM DTC B1323===
===END GEM===
A little more background on the truck. I took it for a test drive. Pulled up to a stop sign on the way back and thought it was a 4 way stop. Ended up pulling out in front of a lady and she ran into the passenger side wheel. Not much damage to the truck. Replaced all that. Found multiple Ground wires going every where, I bet I pulled out 50' of ground wire. Replaced the batteries. All new power cables. Cleaned the engine bay, and under the truck, it was nasty. That was all 4-6 months ago and haven't had any issues until now.
2001 7.3 SD. 197k.. I have read through the string and still have a problem
ABS light on, Speedometer flatline, Flashing O/D on shift. Replaced the VSS on the rear yoke, No improvement. Little heavy oil on old sensor. Connection was good and both tabs intact, no corrosion. Cable routes fine over yolk, no hangups.. I am going to try and clean battery terminals and reapply.
Subsequently now my turn signals don't work, the stick indexes but no dash light or sound, hazards work completely fine. This could be a weird coincidence.. Any suggestions beyond what has been said. I won't discount the new durmast VSS i bought is bad but not sure..
rustyandleaking
12-30-2016 01:16 PM
