Hello, I have a 2017 f250 with only the factory reverse camera on the tailgate. I added a aftermarket front camera and 3rd brake light camera. currently they only work as an overide when the factory reverse camera is on through my upfitter switches. i want a way to force the video onto the radio screen whenever i turn it on such as driving down the highway or pulling into a parking spot. I know it is possible because i saw a youtube video of it. I have forscan and am unsure what i may need to do to allow this or if there is some form of wiring i need to do. if anyone has any info or tips i would heavily appreciate(note i do NOT have 360 degree cameras or a camera button on my dash), this is the video of what i want to be able to do.
I had to buy a module from 4dTech to override the CHMSL camera shut off once a certain speed is reached. It was kind of pricey for only having that one function. I removed the module from the 2022 that I traded back in January and it sits in a drawer now. It's been advertised on the local FB Marketplace for months with zero interest.
That truck was also a non 360 unit. It's been discussed and work FORScan workarounds have been attempted by knowledgeable guys like ZooDad but I don't recall a solution ever being found.
and it enabled you to manually switch the camera on while moving??if so how?
Just pushing the camera button on the dash. I could be rolling down the road at highway speed, push the camera button and the rear CHMSL camera will come on.
As stated it was a non 360 camera truck. But I did order it with the CHMSL camera from the factory. No idea if it would work with an aftermarket CHMSL.
With my current 360 camera truck I can turn cameras on at any speed from the factory.
