Brake Job Torque Specs
Old Jun 9, 2021 | 06:18 PM
JayCarver's Avatar
JayCarver
Does anyone have the torque values for the brake components handy? I have a brake job to do tomorrow.
Thanks in advance.
Old Jun 10, 2021 | 12:24 PM
HRTKD's Avatar
HRTKD
You failed to specify which vehicle you have. It matters. DRW specs are very different from SRW. 4x2 versus 4x4 are different.
F-250/F-350 SRW
Brake Caliper: 55 lb.ft (front and rear)
On other vehicles I've done brakes on there is a slider pin and a torque setting for that. Maybe my reading comprehension is low, but I can't find that in the Ford service manual.
Old Jun 10, 2021 | 01:24 PM
landman873's Avatar
landman873
I just put them tight and usually use a dot of blue loctite
Old Jun 10, 2021 | 01:58 PM
whagen's Avatar
whagen
" deleted "
Old Jun 10, 2021 | 09:49 PM
Killer-Bimmer's Avatar
Killer-Bimmer
This is from '21 Service Manual for Future Reference:
Old Oct 22, 2024 | 03:46 PM
Icelink's Avatar
Icelink
Old thread but exactly what I needed thanks for posting your a lifesaver years later !!!
AAA+++
PS
What program/manual did you post from ?
What is the cost if you don't mind me asking?
Cheers
Old Oct 22, 2024 | 04:15 PM
Killer-Bimmer
AAA+++
PS
Cheers
No problem and it’s been some time since I’ve even posted.
I originally order digital manual/CD from:
https://www.helminc.com/
Then just used screen capture to post.
Looks like price went up $50 . Inflation I guess… has been worth the price though as I’ve used for many different projects. I use to get some good stuff off the Ford upfitters site as well, but Ford has ruined that site.
Cheers
Old Oct 22, 2024 | 05:17 PM
Icelink's Avatar
Icelink
Cheers
Will check that out thanks so much!!!
Never heard of ford unfitters, FTE has been my goto since 2019 and your post made it 10X better
Cant believe how hard it is to find correct torque specs sometimes
Old Oct 22, 2024 | 06:26 PM
Killer-Bimmer
The site is still there just much harder to find what you want. They use to have them listed out by year and was easy to find. Takes way more time unless you know the bulletin number:
https://www.fordpro.com/en-us/upfit/publications/
lucky I safes most everything I needed i.e. high idle fuse guide etc.
And agree, finding correct tech information seems to be harder and harder, the manual cost is a little steep, but if you plan on keeping truck for long time it’s a cheap investment; though can be tough to find the right information as well the way they have laid out.
Old Oct 23, 2024 | 10:34 AM
porthole's Avatar
porthole
Thanks for the link.
And it appears it's been awhile since I ordered a service manual !
justicem
Escape & Escape Hybrid
Oct 23, 2024 09:34 AM
hop
Oct 31, 2009 11:45 AM
pminne
Jul 29, 2008 10:07 PM
