can the fleet program be used some how if you are not a fleet. it has soft switch you can setup on the screen to run items you install after you build and receive your truck. it is like the uplifter switchs but on screen.
You are referring the the Vehicle Integration System 2.0
in order for it to function, it needs to be provisioned by an upfitter who has access to the configuration tool. Ford controls that tool very tightly. You would need to find someone local with access to the tool and pay them for the time to develop and load a configuration for you.
Pro Upfitter I think was what I ordered on mine. It can control accessories via the center display. But as mentioned about it needs to be programmed by an approved upfitter.... Not a lot of information out there on it. I think it was an additional $400 when I ordered my truck.
It was originally called Pro Upfit Integration System, then they rebranded it. Either way it is option code 18A
