Computer Chips & Tuners
toggle switch question?
Old Aug 10, 2002 | 11:11 PM
Hiexcur's Avatar
Hiexcur
Is there any easy way to tell if you are running program 1 or 3?
Russell
P.S. Thanks for the call Ken.
Old Aug 10, 2002 | 11:25 PM
FTE Ken's Avatar
FTE Ken
1 (tune 2) is on the side with the notch, 2 (tune 1) in the middle and stock on the other. There should be a paper with the chip identifying the settings and I recommend you photo copy it for reference.
Old Aug 10, 2002 | 11:41 PM
Hiexcur's Avatar
Hiexcur
Wow that was quick! Just want to verify, the notch is on the switch body?
Russell
FTE Ken's Avatar
FTE Ken
On the threads. Plus you'll see a small piece of metal sticking out on the same side.
Old Aug 10, 2002 | 11:53 PM
Hiexcur's Avatar
Hiexcur
thanks ken
I'll check it in the morning. I give everyone the results.
Russell
P.S. the instructions on the install was easy to follow. I would suggest that you maybe put in the instructions that it is easier to remove the 10mm bolt on the wire harness (engine bay side of the fire wall)if you remove or pull back the fender well liner. I was unable to get to the bolt from the engine bay side. oh I didnt see any instructions on the toggle switch install?
Old Aug 11, 2002 | 11:11 PM
Hiexcur's Avatar
Hiexcur
One more question, can I install the diablo led switch at anytime?
Russell
Old Aug 12, 2002 | 07:11 AM
FTE Ken's Avatar
FTE Ken
Yes, the cables are removable. You remove the current toggle and plug in the LED toggle.
Old Aug 14, 2002 | 03:51 PM
FTE Ken's Avatar
FTE Ken
Dennis Russell
New Member Introductions
Mar 31, 2013 06:48 AM
Hiexcur
Jul 31, 2002 09:10 AM
Russell Leonhardt
Sep 11, 2000 09:27 AM
Russell Leonhardt
Aug 6, 2000 06:04 PM
Russell Leonhardt
Oct 8, 1999 11:30 AM
