Friendly reminder
Old Sep 30, 2024 | 12:01 PM
joe blow's Avatar
joe blow
Friendly reminder
I am doing some work on the truck and noticed BOTH of the differential breathers were compromised (hole in hose from rubbing). Like most I rarely look at stuff like that because at a glance I see a hose and move on. The rear is nothing but a 45* vacuum connector (at the end) and the front is an open hose snaked into the LH frame. Mind you I've not had any type of moisture or water in the times I changed out the fluid, but I was not going to leave them as is.
Anyway for those that care I redid the breathers so the chance of water getting in there is next to zero.
I purchased two of these :
Amazon Amazon
Went to Lowes and bought two FNPT 3/8" to FNPT 1/4" iron pipe reducer and two NPT 1/4" to 5/16" barb and used 5/16" fuel line I had in my box of hose, along with #4 clamps.
Old Sep 30, 2024 | 12:21 PM
TooManyToys.'s Avatar
TooManyToys.
The iron will rust and clog. You need:
https://www.homedepot.com/p/Everbilt...KRtV&gclsrc=ds
Amazon Amazon
Old Sep 30, 2024 | 12:48 PM
joe blow's Avatar
joe blow
I thought of that also, but slim pickings at my Lowe's like always
I tired to find an alternative but could not. I painted these for now and will probably swap them out eventually.
Thanks for the link (and reminder)
tomkins
Apr 12, 2022 11:12 PM
Tugboatguy
All Things Towing
13
Sep 18, 2021 12:11 AM
MsKitty
Jun 19, 2021 01:51 PM
mrclean667
May 11, 2010 10:36 AM
bountyhunter
Garage & Workshop
Mar 9, 2002 11:26 AM
