Potable water hose
Old Sep 12, 2021 | 03:05 PM
Tugboatguy's Avatar
Tugboatguy
Potable water hose
I’m looking for a new potable water hose. They come in 1/2” & 5/8” diameter. Is there any real world benefits to the larger dia hose?
Thanks.
Old Sep 12, 2021 | 04:55 PM
Jimmy's Pilot Service's Avatar
Veteran: Navy
Maybe...
Having a 5/8" hose for more flow makes no difference if it is only supplied with a 1/2" line on the other side.
On another note if buying a new hose and the possibility of being in a cooler environment consider a hot hose (heater element with insulation). Defiantly Food Grade.
Old Sep 12, 2021 | 06:39 PM
Tugboatguy's Avatar
Tugboatguy
Thanks. The PEX tuning inside trailer is 1/2”.
Old Sep 12, 2021 | 07:29 PM
KU4OJ's Avatar
KU4OJ
I consider potable water hoses to be somewhat expendable or consumable. 2 or 3 seasons and I think I've gotten good service out of them. So I buy them at WalMart or Home Depot.
I think the 5/8" hose takes up a little more space in the storage bin. If looking at the two on the store shelf I'd get the one that seems to be better made. I don't think diameter is going to make that much difference.
Old Sep 12, 2021 | 07:59 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I use a regulator to control the flow of water into the trailer. So, the diameter of the hose was not a concern for me.
On the other hand, the storage capabilities and durability is very important to me.
I have been using 2 of these in 50 ft lengths for a couple of years and they have been great.
Amazon Amazon
Old Sep 12, 2021 | 09:00 PM
BirchyBoy's Avatar
BirchyBoy
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I used those as well until I read some posts about the interior lining falling apart. I switched back to regular kink-free water hoses.
Old Sep 13, 2021 | 07:48 AM
scraprat's Avatar
scraprat
Top Answer: 5
Faucet to trailer really isn't going to make a big difference as mentioned be sure to have the proper regulatory on for water pressure so you don’t damage a line/ connection inside the trailer.
A camco (blue color) hose will do the job at hand.
Old Sep 13, 2021 | 10:27 AM
HRTKD's Avatar
HRTKD
I go with the larger diameter hose, as long as the fittings aren't restrictive. My hoses are almost always used to fill the fresh water tank. At 120 gallons it can take a while to fill. The larger diameter helps. I bought two new Valterra 5/8" hoses last year. A few weeks ago one of the fittings just popped off, spraying water everywhere. It had been leaking for a while, so I should have suspected something was up. The hose was OK, just a bad fitting and a lousy crimp. I put on my own fitting and it's fine.
I've been looking at the lay flat hoses. They take up a lot less space that the traditional tube type hose. This one fills all my requirements except that it's expensive.
Amazon Amazon
Old Sep 13, 2021 | 11:34 AM
Pugga's Avatar
Pugga
I'd focus on hose quality rather than diameter. As noted above, you're connecting to 1/2" anyways. I like the Camco blue hoses. The Camco white hoses are absolute garbage, they kink easily and sometimes won't seal at either end. The blue hoses are heavier with better end connections.
Old Sep 13, 2021 | 12:47 PM
Qvan666's Avatar
Qvan666
Those are the same things I use. I store them with a pressure regulator in a small container of their own to help prevent contamination. They work really well and store even better.
bob
Old Sep 13, 2021 | 03:38 PM
Tugboatguy's Avatar
Tugboatguy
Thanks for all the replies. I appreciate your help.
Old Sep 13, 2021 | 03:44 PM
BC2019F250's Avatar
BC2019F250
Flexzilla Hoses are light weight, durable and come in a lot of sizes. I have been using the same hose for 3 years and it looks like new.
Amazon Amazon
Old Sep 13, 2021 | 07:36 PM
djousma's Avatar
djousma
https://www.amazon.com/s?k=flexzilla&ref=nb_sb_noss_2
Was just going to say the same. Plus ZERO hose taste. By far the best hose I've used. And there had been many
Old Sep 18, 2021 | 12:11 AM
Jfk69's Avatar
Jfk69
Another vote for Flexzilla. Excellent quality, durable, no kinks.
MsKitty
Jun 19, 2021 01:51 PM
Spktyr
Jan 8, 2016 10:45 AM
Wrench Bender 117
Nov 10, 2013 12:29 PM
bountyhunter
Garage & Workshop
Mar 9, 2002 11:26 AM
