Do fuel additives really work?
Old Oct 6, 2024 | 05:56 PM
  #76
FishOnOne's Avatar
FishOnOne
Originally Posted by Overkill2
Speaking of fuel, and the original CP4 your truck is still rocking Troy, how many miles on your truck now?
Old Oct 6, 2024 | 06:07 PM
  #77
Overkill2's Avatar
Overkill2
Originally Posted by FishOnOne
I know a Ford tech, works at my buddy's auto shop where I take my truck, who picked up a used F250 or 350 with a 6.7 and 285k miles with what looks like the original CP4. He checked the records and cant see any indication it was replaced... He just installed a S&S DPK and will install a DPK next year... I thought of you with that kind of mileage...
Old Oct 6, 2024 | 07:32 PM
  #78
wcbcruzer's Avatar
wcbcruzer
That's pretty cool. I'm pretty sure the Ford engineers figured out what fuel rate/pressure to feed the CP4 to compensate for decreased ULSD lubricity here in the US. Sort of like... as long as everything is perfect (ie. good fuel, no water, etc), then there will be no issues for many miles, but if there is a tiny pebble on the track, it'll derail the train. It can only help to run an additive. The reason Ram and GM had more CP4 failures is probably because they didn't know better at that time, and then never really looked back after changing pumps.
Old Oct 6, 2024 | 08:19 PM
  #79
Overkill2's Avatar
Overkill2
I know for a fact the earlier Duramax trucks did not have a primary pump like the Fords came with right out of the gate. Not sure on the Rams. So having your HPFP pulling from the fuel tank definitely did not help those GM trucks.
As to the Ford engineers compensating fuel rate/pressure for the CP4, its neither. Common rail engines need enough fuel at high pressures to produce the power they are. Bosch makes the CP4 pumps and injectors if I'm not mistaken... I'm not a full time mechanic. Just read a lot.
For the later trucks, they had a special coating i believe inside the pumps to help, longer stroke and maybe bore (?), and did pin the rollers so they couldnt rotate in the housings... IIRC...
As to additives, yes, they can't hurt...
Old Oct 6, 2024 | 08:30 PM
  #80
wcbcruzer's Avatar
wcbcruzer
Wow, is that right? I did not know that. Pinning the roller is a huge achievement if they did that.
Old Oct 6, 2024 | 08:34 PM
  #81
Rich1961's Avatar
Rich1961
I just helped a friend install his DCR on his 2017 6.7 with 380k on it. Original CP4 and he had installed the DPK about 100k ago. We were replacing the Turbo and since everything was opened up, he decided to be proactive and get the DCR done at the same time.
Old Oct 6, 2024 | 09:09 PM
  #82
scraprat's Avatar
scraprat
Top Answer: 5
This is what I'll be doing in a month or so is replacing the Turbo and while it's open upgrade the CP4 to DCR. Except my truck only has 68k miles on it.
Old Oct 6, 2024 | 09:48 PM
  #83
Overkill2's Avatar
Overkill2
Which truck Rat, the 16 I'd assume?
Old Oct 6, 2024 | 09:50 PM
  #84
Overkill2's Avatar
Overkill2
Yeah, I ever have the DCR installed, I'd either have my turbo rebuilt with a full 360 thrust washer kit or buy new... we'll cross that bridge when we get to it I guess.
Old Oct 6, 2024 | 10:00 PM
  #85
Overkill2's Avatar
Overkill2
I'm no expert but have read that stuff here... someone with more knowledge on it should chime in...
I believe the "buckets," if that's the correct term, that holds the rollers that ride on the cams, were pinned for MY2020... I'm pretty sure.
About the coating, I remember reading that somewhere... maybe started with the MY15.
Here's a good thread on Bosch CP4.2s...
https://www.powerstroke.org/threads/...grade.1396427/
Old Oct 6, 2024 | 10:07 PM
  #86
Rich1961's Avatar
Rich1961
If you don't have one, get yourself a Top Side Creeper, makes both the turbo and DCR install much easier on your back.
Old Oct 6, 2024 | 10:27 PM
  #87
Overkill2's Avatar
Overkill2
I bought one of these for my DPK install last year. I love it... just used it again today... also adjustable height and rock solid as well.
https://bulletproofdiesel.com/search...ct&q=tech+step
Old Oct 7, 2024 | 06:55 AM
  #88
scraprat's Avatar
scraprat
Top Answer: 5
Yes the '16'. Getting close to heading south with the 5th wheel and it's only a short time before mother nature starts dropping snow on the mountain passes.
Old Oct 7, 2024 | 07:23 AM
  #89
rufushusky's Avatar
rufushusky
Yeah GM didn't see the light on low pressure fuel systems until the Denso system showed up in 2017, all the bosch fuel system trucks did not have a lift pump from 2001 to 2016. How on the lord's green earth they thought a CP4 could survive pulling its own fuel is beyond me. Dodge's low pressure fuel systems are as bad as their inhouse transmissions IMHO and Cummins ham-fisted the cam speed on the injection pumps, supposedly. Not saying the CP4 is in the same league as the P7100 or CP3 but properly set up and maintained it can survive better than most people think.
Old Oct 7, 2024 | 09:05 PM
  #90
acdii's Avatar
acdii
Crack open that pump once it is off and see how the wear is. Pretty sure we are all wondering what it looks like inside.
